Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Monitor on but not working properly
I just got a computer built and a friend loaned me their Dell UltraSharp 1800fp monitor. I connected the DVI cord and the monitor turns on, but nothing happens. I set up my wireless mouse, which works fine with my laptop.
The monitor screen says stuff about IDE Channels and Warning! CPU has been changed...please re-enter CPU settings in the CMOS setup and blah blah blah. How can I change any settings if nothing is working? Any ideas, please help!
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
Or you can reset the cmos jumper as well
Posted on Feb 24, 2008
    Sniper:
  • 67 Answers
If you just built the computer..the motherboard will give you a warning that some hardware has changed. you have to connect your keyboard and go into the bios and make sure everything is right. To be safe select set to default factory settings , save and reboot the computer. This is to prevent the settings for a previous cpu be used for the new one.
Does ultrasharp's 1800fp monitors have built-in speakers?
No built in speakers. There is a sound bar that you can get the attaches to the bottom of the screen to add speaers to the unit but it is sold separately.
Sep 26, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800fp dead
Each monitor has a different response to "no activity" from the system. So for the monitor, if you get a chance, try your monitor on another machine that you know does function. At work, neighbour, or other.
For the computer, does the it (beep) or POST (Power On Selft Test) when you turn it on, do you see and hear what you would if the monitor was connected?
If it sounds normal, then everything should be fine and luck might have it, your backup monitor is not working either, try another one from the same friend or neighbour above.
If it doesn't POST, you could have a video or other card or ribbon connection loose in the computer. Either you or a friend, or the service center, whichever feels comfortable reseating all the external and internal equipment, bearing in mind static electricity and proper handling measures for the computer.
Nov 26, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Green tint
Sounds like the monitor cable has a short or loose connection at computer or monitor side.
May 24, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell w3206c no turn on
Biker,
The power cord is probably loose.
check the cord where it connects to the monitor and push it in to re-seat it.
Nov 11, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP monitor. Will not power up at all. Checked power cord on another machine, works fine. Monitor is from 2002, but was working perfect till yesterday. Is this worth fixing?
Take it apart and check the fuse. Sometimes is just a simple component damaged.
Have it checked in a specialist electronics house if you prefer.
Sep 17, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
1800FP Dell Monitor Light continuously blinks no picture
I have made a solution to this and it can be found on my website here:
http://www.dorchestercomputerrepairs.com/1800.html
Hope this helps.
sparkyuiop
Sep 28, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell ultrasharp blinks on and off
It could be a setting problem, power saver setting, or a mode that the monitor does not really support - things like refresh rate - or actual hardware.
Easiest way is to borrow another like monitor, and say another video cord and see if the problem remains, or if a newer monitor says 'out of range' or similar.
Then, if you have a fancy video card,remove it and use something primitive. Not reading instructions is a big cause.
If its not a setting issue, and as the inverter board is ok; if the above description is correct, reseat the inner board connecting cables.(wood fires and seaside locations) If not that, a lucky guess might be the electros on the logic board.
Aug 20, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Analog Dead/DVI OK
Sounds like the video controller board inside the monitor has blown a transistor. They are only about 3mm wide so not easy to spot even if you look closely.
It's a fairly rare fault, though not unknown to happen without reason.
Nov 14, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
117 people viewed this question
Alun Cox
