Rca scenium hd52w140 chassis atc311 looks a bit fuzzy .....
Just got this thing running again tonight and the screen looks a little out of focus or fuzzy. also anything black looks kind of bright ; i tried the auto converge and it couldnt complete because one of the sensors is bad; it hink it said. any ideas on what i can do to make this tv look clearer and anything about the sensors? it stops on the first convergence color green. thanks a lot. i had it working a week ago and did the auto convergence no problem. think i could have jarred something lose? where would be a good place to start. thanks again
  • jetedwardz Feb 25, 2008
    dont bother with response i got the thing lokking great and bam another hv splitter blew again this time i put in a new flyback too
  • jetedwardz Mar 26, 2008
    what is the hfl? do you now the location number too thanks
Hfl
Posted on Mar 25, 2008
RCA scenium model hd50lpw165. lamp went out- replaced it but tried so many times to turn it on before realizing the bulb needed to be replaced that it locked up. what to do?
http://www.tvtechcenter.com/board/links/rca/ATC311%20Training%20Manual.pdf
OK above is a service and training manual this is what engineers use to teach engineers how to fix sets like yours Use this an you may be able to repair READ THE SAFETY INSTRUCTION FIRST.
Apr 29, 2010 | RCA Scenium L50000 Television
Tip
HD52W140 White screen with retrace lines then shuts down
This has the ATC311 chassis. I have found that capacitor C14703 has actually been loose on the deflection board and that had caused the set to have a white screen with retrace lines then the set would shutdown. I resolderd this and normal operation was resumed.
on Feb 23, 2008 | RCA HD52W140 52" Rear Projection...
Rca 42 inch hdtv the screen is fuzzy and turning blue .. how can I fix this problem
please check the arial connection also please check the colour it needs reajusting. take it back to b/w and retune.
May 04, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium HD52W140
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca scenium hd52w140 wont power up.... again
Sounds as if you'll have to replace the regulator and filter cap for it, at the very least. You may have taken out the flyback again, as they're not very hardy when driven with too much AC bias. The arc that you are calling a spark will have to be addressed also. If you have an intermittent connection at that point, the feedback voltage will be incorrect and you'll have the same scenario on dealing with a dead set once again. Hope this helps....accordianman
Feb 19, 2008 | Televison & Video
Poor screen resolution and unable to get channel guide.
The channel guide is a service just like closed caption. Rumer has it that it's not going to be around for much longer. The only fix is to unplug set ..wait awhile till memory loss occurs...plug back up and do a setup. Nothing in the TV will cause partial guide. Weak signal could and cause fuzzy picture too. Complain to cable company. But brightness problem is something else.
Dec 27, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
HD52W140YX!
Check first R14705 to see if burnt! If so then HV Trans is bad. Also if you need schematic try www.servicemanuals.net
Oct 08, 2007 | RCA HD52W140 52" Rear Projection...
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Tv F27442
The TV does not have a reset button. If you have no picture and no sound, there is something wrong with the chassis. In this case the set should be serviced by someone experienced in the RCA CTC203 chassis. If you have no picture but do have sound, then it is possible that the 2 controls in the 2 little holes in the back of the set are not adjusted correctly. This is quite possible since you said you put a screwdriver in there and got a fuzzy picture. The control on the bottom is called "screen" and is the overall brightness of the picture and the control on top is called "focus" and is the sharpness of the picture.
May 20, 2007 | RCA F27442 27" TV
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
