Question about Power Acoustik TS1440-2 Car Audio Amplifier
Amp My protection light keep going on and off
    Problem Solver:
  • 12 Answers
Try turning down the gain a little bit. or check the ground and power connections at amp and battery. they may be loose
Posted on Feb 25, 2008
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
My visonik v700hc keeps going into protect modeafter listening for a couple minuits then will go green light then back to red after a coupke more any solutions
I suggest checking what ohm load you're presenting to that amp. go to www.the12volt.com and find the subwoofer wiring diagram and choosing the amount of subs you have on it and then the impedence of each one. you're probably sending too low of an ohm load to the amp this would cause it to go into protection quite frequently and eventually stay in protection.
May 30, 2010 | Visonik V700HC Car Audio Amplifier
Protect light keeps comin on
MAKE SURE THE GROUND IS GOOD ON BODY OF CAR BOTH UNDER THE HOOD AND WHERE YOUR AMP IS GROUNDED
Apr 18, 2010 | Infinity Reference 1300a Car Audio...
THE PROTECTION LIGHT COMES ON
make sure your ground is drilled threw thick metal and the paint is scraped off and make sure that all the wires connecting the amp are 4 gauge or higher and if that doesn't do the trick get a better amp that can throw more power
Mar 29, 2010 | Lanzar Vibe 1200D Car Audio Amplifier
Xm-2002gtr amp keeps kicking protect light on
check your amp and speakers and make sure their both hooked up 4 ohm instead of 2 ohm because if you have 1 set of voice coils on your speakers they can only be hooked up four ohm and not bridged to your amp because if you keep trying this you will lock up your speakers if the speakers are only 4 ohm than just hook them up regular to each channel on your amp if your trying to brigde four ohm speakers to your amp it will keep going into protect or worst case scenario you will fry your speakers and you can check your ohm with a ohmmeter trust me my brother owns a stereo shop
Oct 19, 2009 | Sony Car Audio & Video
Protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
May 28, 2009 | Jensen LXA300 Car Audio Amplifier
My amp wont work
The amp probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 24, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
My amp
Check your speakers with an ohm meter. They should have some resistance but not totally shorted. Its prob the amp that got fried. Connect the amp to the battery with no speakers attached to it if the protection light still comes on then the amp is blown.
If the amp is blown you can send it to people on ebay and get it fixed pretty cheap. Good luck!
Aug 18, 2008 | JBL GTO75.4 Car Audio Amplifier
Power Acoustik TS1440-2 Car Audio Amplifier Logo
61 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
