Pellet stove the lopi foxfire PI pellet stove i had worked great most of the winter. Havent used it for a few weeks but the furnace in my 107 year old house just went out and we are FREEZING !! Hoping someone can help us get this going so we can have a bit of heat until the furnace is fixed. I press the on button then the start button same as always but then the thing just makes this buzzzzzz. I checked the fuse on the back (black knob that pulls out) it seems fine. the light on the "on" "power" switch is on and their is a slight tick from the auger - but it doesnt turn - I've had an auger jam before - but i didnt just do this buzzing. any clues ?? oh and if you do have help for me, please ... speak in "blonde" thank you !
  • 1 more comment
  • Rebecca Lents Feb 27, 2008
    its a lopi foxfire pi ( or PL ) but i think its PI400. I've always ignited it by putting some pellet in the tray - turning it on and holding a lighter on them until they burn steadily - then shut the door. I'll try cleaning out the auger. I've had to do that before - but I thought when the auger was jammed last time it still made a noise like it was running. Thank you so far. Let me know if you can help more. In the mean time I'll dig around and get all dirty again. lol. thank you !
  • Rebecca Lents Mar 03, 2008
    you can directy e-mail me at rzsiempreperdido@sbcglobal.net. I havent gotten into working on it yet but the pellets do seem a bit damp. thank you for all your help - and good luck htmchris !!
  • Rebecca Lents Oct 20, 2013
    runs great when i hotwire the auger ... can i leave it this way or what ... ? please feel free to call 57.-539-9445 i realllly need to fix this fast
Remove all pellets from the hopper start your stove , place a shop vac to the pellet drop down tube , tap on the auger housing located inside the hopper,tap and vac until the auger spins free this will take awhile , but works . Good luck. Ben
Posted on Feb 16, 2013
We are having the same problem, our auger motor won't turn but our fan is running.
Posted on Mar 02, 2008
    Problem Solver:
  • 14 Answers
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Posted on Feb 27, 2008
  • 2 more comments
  • Robb Koschalk Feb 27, 2008
    Auger jams are more prevelant this year due to the poor quality of raw materials used to make them: alot more sawdust. This gets ground up and creates a fine powder that can build up near the top of the auger flight. Does your combustion blower turn on when you hit start? If it does not, then the pressure switch will not close, which keeps the auger motor from feeding.
  • Robb Koschalk Mar 03, 2008
    There are a few things you can check: (1) pull the auger motor to see if you have something jamming it (foreign object or pellets/sawdust) (2) you can run a jumper wire between the two wires that go to your vacuum switch - the silver disc with two wires and the rubber hose going to your exhaust blower (3) you can pull your auger motor off the collar and see that it is working.
    Hey Robb - REALLY appreciate your help. we hot wired or jumped the auger etc and the auger runs great. can we leave it like this or does this tell you what the problem might be ?
    PLEASE call me if you can need this fixed asap. 573-539-9445
Our Fox Fire Stove had the same symptoms. The buzzing sound was coming from the box that has the fuze in it (not the aunger or a fan). I was finally able to get it started after removing the clean out cover and cleaning out the tee elbow -- which didn't quite do the job. So I stuffed rags around a vacuum hose nozzle in the clean out and left the vacuum running while turning the stove on... and that did the trick (sort of kick starting the stove by providing the negative air pressure needed to keep the controls from buzzing and shutting the fan down before it had a chance to get moving and blow more of the ash that was gumming things up out of the system).
Posted on Dec 15, 2012
Testimonial: "Hmmmm ... how did you get the vacuum running ? should it be sucking air from the flow switch ?"
Need a lopi 1998 pellet stove manual. no air comimg out of the fire basket.
hi patty.
this is all i could find.go to this link and see if you can see the manual you are after.
lopi 1998 pellet stove manual Google Search
Nov 03, 2017 | Heating & Cooling
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
WHAT DOES ER2 CODE MEAN ON PELLET STOVE
Which pellet stove do you have? A lot of pellet stoves have a part inside called a Draft Flow Switch the size of your palm and hook to the Draft Flow Switch is a Draft silicone hose and this will get clogged with debris you will need to look at your diagram to see if you have that on your stove. If you do you will need to "gingerly take off the hose and blow through it. and re connected to the draft flow Switch. After sometime the hoses become brittle. Another thing to look at is the exhaust at the back of the stove cleaned out and you are getting your pellet stove cleaned out by a chimney sweep.
Mar 03, 2014 | Us Stove Company Pellet Heater with...
Pinnacle Pellet stove augre gets stuck
hmm, could be low power to the motor, heavier power cord, or it's possible the auger needs new bushing/bearings, wiggle the auger to see if it has any play in it OR it's fussy about the size of pellets it made to feed. please send pictures and or results.
Jay
Jun 08, 2017 | Pool & Spa
What do you need to do to put a woopellet stove pipe thru wall
I'm confused by your question. If you are asking what is involved in installing a pellet stove well it varies greatly from model to model. Generally speaking, most pellet stoves will horizontally terminate behind the stove itself as opposed to running thru the roof like a woodstove does. Pellet stoves require the use of electricity for numerous functions, one of which is power venting thru this rear terminated pipe. As far as clearances to combustables, you will find that pellet stoves are very forgiving in that department, with minimal clearances required. Once again all stoves are different and they all are rated indepentently so my best advice to you is find a quality pellet stove dealer and go in and see them. They will be more than happy to answer your questions. Avoid the big box stores as they have pellet stoves at a good price but offer NO service or installation and believe me, I am in the business, you will need professional service at some point during the life of your stove so don't save a couple bucks by going cheap. You will be happier for it down the road. Good luck.
Mar 12, 2009 | Napoleon Auburn Pellet Stove Heater
Stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
Mar 11, 2009 | Napoleon Auburn Pellet Stove Heater
Pellet stove
i have a goodman furnace 1 yaer old and the burnner mainly late at night keeps cycaling on and of no codes present
Oct 21, 2008 | Heating & Cooling
Pellet insert won't start
When was the last time this unit was clean? and has it been clean through the exhausted pipe?
What type of chimney is on this unit?
Are you using a Preminum Pellet?
Fireplacegirl
Apr 24, 2008 | Heating & Cooling
Heating & Cooling Logo
2,582 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
