Sanyo 32" television
My tv crackles and pops with rolling static but plays a beautiful picture with dvd player or vcr
Crackling and pops signify that your either your flyback, deflection yoke, or HV anode wire is arcing.
Posted on Aug 23, 2008
    Brigadier General:
  • 6,966 Answers
If the picture is OK with DVD and VCR, then perhaps the problem lies elsewhere other than the TV. It could either be your:
1. aerial antenna or
2. cable connection.
Aerials can re re-oriented/realigned to improve reception or reduce interference while the cable would require that you get in touch with your cable provider. In some instances cable problems could be loose connector at the back of the TV. Additionally, interference can be caused by other electrical/electronic devices. Past experience has shown me that even a 2-Stroke lawn mover/grass cutter has these effects.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 24, 2008
No sound on t.v. but popping and crackling from speaker
Sanyo sets have a horrible track record, if the set is still under warranty return it. The problem could be in either the power supply or main board. It will have to be diagnosed properly to be sure.
Oct 22, 2012 | Sanyo DP32746 32 in. LCD Television
What do I need to connect an old TV with only one output on back to a TWC cable box, DVD Player, VCR and a Play Station?
Just connect the PS3 it also works as a DVD player. Do you really need a VCR player? You can get a converter box to stream the VCR footage through the DVD player/ PS3
Aug 06, 2012 | Televison & Video
How do I get the VCR to play on the tv? It's a Sanyo DVW-7100 DVDPlayer/VCR Combo. The DVD will play but the VCR won't show up on the TV.
This maybe too simplistic but are you sure you have the right command buttons toggled try to set the player to VCR and not dvd.
Set the player to VCR with a tape in it and press play. I hope this works for you
Sep 29, 2010 | Sanyo DVW-5000 DVD Player/VCR
My dvd/vcr player has alot of static and lines on the tv
Check and make sure you have the composite cable (5 color cable) connected correctly and you have the NTSC/PAL set to NTSC (north american if applies) If you have a audio out (r/wh) cable into the RGB inputs on the TV, itll knock out a color or chroma channel and itll look strange.
Nov 15, 2008 | Sanyo DVW-6000 DVD Player/VCR
Can"t get vcr or dvd to play on the tele.
If u think that it has some thing to do with the remote control of the TV or the DVD player then firstly u must change the picture quality of the screen from higher to lower or vice versa. If this doesn't works then try playing an audio CD and then see if it is working. If it is played on the System then there is a problen with your Television and if it is not played then the DVD player is corrupt.
Sep 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Vcr
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP for five seconds to restore the
picture to normal operation.
Aug 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
