Question about Western Digital Caviar WD2500BB 250 GB Hard Drive
Have I lost all my info?
I have a WD Caviar - WD2500. It worked fine and I was using it a main drive on my network that I am setting up at home. It crashed earlier today after I put a BUNCH of information on it. I had not gotten to back it up as yet. A lot of music files. The computer seems to know that I am plugging the drive in but I can't get the device to start. Have I lost everything on it or is there a way to recover my files or better yet, get this device working again?
  • rokenn3 Feb 24, 2008
    Thanks for your responses guys. I do not hear a clicking sound nor do I seem to hear the drive spinning. I am running Win XP. The PC recognizes that the Mass Storage Device has been plugged in but it won't go any further. I can accept that there may be something wrong with the drive. BUt I absolutely can't go through months of work converting the files again. Gotta be a way to get them off. Maybe I will take it to Best Buy or something.
  • teresakarpin Nov 14, 2008
    Recognised bur cannot ccess data
    Sniper:
  • 67 Answers
Remove the hard disk from the computer and put it in a zip lock bag to prevent condensation. Put it in your freezer at the coldest temperature setting.
Wait for a few hours and then connect it back quickly to your computer. it will only work for a few minutes so try to get any important data out.
This is a quick fix for a certain type of problem with caviars like the clicking sound.
OR
you may have just corrupted the partition table of the hard drive.
search for repair partition table on google.
i usually use a linux install disk to repair it since there is a utility that comes with it that can edit that part of the hard drive.
Posted on Feb 24, 2008
  • 34 Answers
Can you hear the hard drive spinning up ?
if so you can check it using a hard drive diagnostics tool
http://www.tacktech.com/display.cfm?ttid=287#wdc
If its a hardware problem you can try replacing the logic board. You can get one on ebay or you can get one off of another working hard drive (hard drive must be of the same make/model).
Dead hd wd caviar 80 gb
Is the "dead" hard drive 80GB? or 500GB?
I presume you set up this hard drive as the second hard drive, or as an external drive. You can do these:
1. Disk Management (check the readablility):
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. Is this hard drive info exist in this screen? If it is, then the hard drive is not dead.
Click on the hard drive info, right click, and you can do some actions (format, expand the volume, assign a drive letter, etc.)
2. If necessary, test and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Feb 20, 2014 | Western Digital WD Caviar Green WD5000AADS...
I looking for a pcb boad for hd western digital wd2500 caviar se
You should be able to find one here http://www.hdd-parts.com/wd-caviar-se.html
Jul 16, 2011 | Western Digital Caviar SE WD2500JB 250 GB...
I lost the power supply for my WD2500 external HD.
My Book Essentials
12 Volts
3.0 Amps
36 Watts
Sometimes WD will even send you a replacement free of charge, if you give them a call.
Jan 24, 2010 | Western Digital 250GB MyBook External USB...
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Installed more ram and now can't find the hard drive
Pull out the new RAM chips and install the old one or ones and see if it boots ok. I had this same problem. This can also be caused by no using matched sets of RAM chips. In my case I added one and used the factory one as well, caused the same issue as you have.
May 19, 2017 | Western Digital Caviar SE 80 GB Hard Drive
Hard drive circuitry damage??
simply find a harddrive with the exact same model number and date, then swap the boards.
Nov 29, 2008 | Western Digital Caviar SE 120 GB Hard...
WD Caviar SE 16
Have you installed it as the main drive, ie the one with the ops system on, or have you installed it as a secondary drive? Either way, check you have the drive set up correctly as per instructions on pack. You are not alone with this problem either, it is common with WD. Come back to me with more info re your install.
Personally, I would set it up in an external enclosure and access via USB. Much more realable that way, and it is portable for you.
Apr 14, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Can't connect
you may need a new drive. Take it to a data recovery place(Phoe book) and get the musicoff of it, then put it on a new drive.
Feb 24, 2008 | Western Digital Caviar WD2500BB 250 GB...
Problem with SATA WD Caviar SE WD2500AAJS hard drive model
Maybe the sata controller on your motherboard is disabled. Try searching for the settings of your sata controller on the bios and enable it.
Jan 02, 2008 | Maxtor Hard Drive
Western Digital Caviar WD2500BB 250 GB Hard Drive Logo
379 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
