I can't be sure but this may be made by Nakajima so check the slide switch for pitch on the left side it may be in PS proportional space. DickyOI can't be sure but this may be made by Nakajima so check the slide switch for pitch on the left side it may be in PS proportional space. DickyO
You can't post conmments that contain an email address.
The print hammer is striking between the letters. Two thing
you may have a petal, letter broken off. If its the same letter every time usually thats it, need new daisy wheel.
Or Homing is off when the wheel turns hammer hits between letters. Needs repair.
Or
Daisy wheel petals are bent.
Check the printwheel for any broken or bent spokes. vertical lines means the wheel is between letters so either a problem with printwheel or something preventing wheel from turning normally.
The wheel usually last for many years. I'm assuming you are getting 2 vert lines in place of the missing letter (hammer face). Used replacement wheels are available for 29,95.
Not good. You probably turned the element while removing it and if you are lucky had it come off one of the pulleys, but more likely it came off the wheel under the element. Then you will need a tech.
Linda,first of all,does the daisy wheel spin when the typewriter is first turned on? if it does,then you will feel assured that it is installed properly. Next, refer to your manual to key board settings. It will indicate that there are settings for normal standard English keyboard and somehow that setting may have been changed. It would be also be important to check the daisy wheel to see if it is compatible with standard English keyboard...Cheers, John
Does it always type the same wrong letter ie
a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
