Question about GE 24 in. GSD5560GSS Built-In Dishwasher
Will not drain
After a complete cycle, There is almost 2 in of water still on the bottom.
I have cleaned drain hose and cleaned the pump.
What else could cause this?
  • Anonymous Jan 15, 2009
    same problem, about 2" of water and will not completed drain.
Disconnect the drain hose from the pump, push stiff cable wire inside the hose up to the drain turning the cable wire has you push, reconnect hose to pump, re-install dishwasher run through full cycle.
Posted on Jul 17, 2008
  • 105 Answers
Pull the check valve in line after pump this my be jamed if not the pump may need replacing
Posted on Feb 24, 2008
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
My zanussi da6142 is stopping near the end of its cycle and will not drain regardless of which cycle i choose
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, to clean it you have to take off the bottom front panel and then clean the drain pump assembly. If you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Dishwashers
My GE Model #5500 does not drain the water after a washing cycle.
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, to do this you'll have to take the front bottom panel out and then clean it completely. If you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Maytag Dishwasher
I keep getting a failure with a code 2 before my front load loader whirlpool washer cycle is complete. The washer is about 7 years old.
f 02 is a drain issue
check the drain hose make sure not plugged or kinked
check electrical connection at drain pump itself
on this unit there is a cleanout at bottom behind kick plate remove the 2 or 3 screws from bottom and you will see a a plastic clean out have a few towels ready or a wet vac works great...make sure you unplug unit during this as electricity and water do not mix well...
pull cover on clean out and check for any foreign material and while in there check pump impeller for coins also move hoses sometimes objects in hoses right before pump ....if all this does not correct you have a bad pump assembly most likely...
good luck and please vote...
Jan 03, 2011 | Whirlpool Washing Machines
Water in bottom after cycle is complete
After completing the cycle if the dishwasher still has water in the bottom that means that it is unable to drain. This problem occurs when either the drain hose is blocked or the drain pump itself has gone bad. To solve this problem you can check the drain hose and try to clean it before replacing the pump. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Dishwashers
D/W does NOT drain. Water remains in bottom after cycle is completed
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
Oct 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
MY GE DISHWASHER IS CONNECTED AND RUNNING, UNIT HA...
hi just try this Is the door open or unlatched?
Make sure the door is completely closed and latched.
Was the selected cycle interrupted before completing?
The Clean light will come on when the cycle is complete. Wait until the Clean light comes on before trying to manually drain dishwasher. Press Cancel/Drain to try and drain the standing water.
Is the water level just covering the pump module?
This is normal. A small amount of water will be seen in the bottom of the sump area at the base of the pump. This is to ensure that the pump seal does not dry out.
Is the dishwasher drain hose connected to a garbage disposal?
For many dishwashers, the drain hose is connected to the disposal and the knockout plug must be removed from the disposer inlet.
Is the drain system blocked?
Run the disposer to clear the drain system.
Do you have an air gap at your sink?
Check to see if the air gap is blocked by foreign material. To clean the drain air gap, follow the cleaning instructions provided by the manufacturer. With most types, you lift off the chrome cover, unscrew the plastic cap, and then check for any soil buildup. Clean if necessary.
Is there a loop in the drain hose less than 20" (50.8 cm) above the floor?
Make sure the drain hose is looped up so that it touches the underside of the counter before connecting to the sink drain or disposer.
Is there a kink in the drain hose?
Replace a kinked drain hose.
Did you reuse an existing drain hose?
Make sure to use the new drain hose that came with the dishwasher.
Is the sink drain clogged?
If the sink is not draining well, a plumber may need to be contacted. Most dishwashers connect to the sink drain. If the sink drain is clogged, the dishwasher can't pump out water.
Is the drain hose too long?
If the supplied drain hose was replaced with a longer one it must be shorter than 12' (3.7m).
May 17, 2010 | Dishwashers
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
GE 24 in. GSD5560GSS Built-In Dishwasher Logo
193 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
