Question about Whirlpool RCS3014 Electric Cooktop
Help i was cooking and my cooktop made a poping sound and just turned off cant get back on wont work
  • lolipop32 Feb 25, 2008
    well i found that my cooktop bounces my braker so something caused the popping sound and made it turn off . went out and put the braker back on so if you can let me know what could be causing this we did open it and some white squares look like burn inside
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like you got a short(probably one of your switches. do alll the knobe feel as if they're turn the same.usally when one shorts out itll operate differntly no resistance in the switch, can you lift stove top up and look under generally a visual inspecton will show where "pop" occurred
Posted on Feb 24, 2008
  • Ron Coons
    Ron Coons Feb 25, 2008
    that white square where the burn marks are is whre th problem is located, thats whats shorting you braker, theyll need replaceing
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
Caps come on my cooktop but indicator light wont come on
Hi George - Thank you for your post! Let's try resetting the cook-top by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control) or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Jul 13, 2013 | Frigidaire 31 in. FEC30S7E Electric...
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Poping sound, sparks shooting out and 220 circuit breaker out
Did you move the breaker fully off before turning it back on? make sure the offending burner is off.
It sounds as though the element shorted out.
Mar 17, 2009 | Jenn-Air JED8430 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Melted plastic help!!!!!!!
While the cook top is cool, use a razor blade scraper to remove most of the melted plastic.  Turn on the cook top to warm the remaining plastic slightly, turn off the cooktop,  and then wipe off the excess.
Sep 23, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Whirlpool RCS3014 Electric Cooktop Logo
349 people viewed this question
Top Whirlpool Cooktops Experts
vince
Timllfixit
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
