Question about LG 37LP1D 37 in. LCD Television
A mirror fell on the tv and knocked it to the ground
Now tv won't turn on. Red power button just flashes constantly.
  • EL DERICK Jun 16, 2008
    Ola.Hace unos dias me paso que el LG 37LP1D me fallo ,es decir,lo fui a encender y nada, me parpadeo el led rojo haciendo ( clic clic) y no paso a verde y por mas que lo intente sigue haciendo lo mismo, si alguien sabe como solucionarlo por favor diganmelo, ya veo que esto le esta pasando a muchas gentes segun puedo lee en esta pagina
    mi nombre es Derick. Gracias
    y ojala podernos ayudar uno al otro siempre
Fff
Posted on Jun 17, 2008
Gracias SP8, no me quedara otro remedio que mandarlo al Taller,pero si es posible, dime que es el famoso PCB y si tienes idea de porque se daña y asi evitar posibles accidentes futuros.
Gracias SP8
    Habit-Forming:
  • 166 Answers
If the mirror broke then your in for 7 years bad luck and it has already started, most likely PCB has been damaged take it to a repair shop for an estimate
Posted on Jun 13, 2008
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
TV will not turn on, only flashes green status light on front constantly, any suggested fixes?
A button may be stuck down, this is what happened to my TV when a button was stuck.
Dec 08, 2015 | Mitsubishi LT55164 55 in LCD TV
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
TV won't turn on
it is maybe power supply is damage,please check the fuse of power supply,if it is fuse is damage,you can change it.if fuse is ok,you can change power supply boards.when you find which boards is defective,you can search by pcb number on www.wisiny.com
Jun 05, 2013 | Craig CLC501 15 in. TV
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
My Sabre LCD TV is blinking red and green on power button and will not come on
My TV just did this 2 days before Thanksgiving. I just messed with it and fixed it today. Unplug it from the power source for atleast one hour. Plug it back it. Hold the power button til constantly flashes red and green. Wait at least one minute while it continues to flash. Turn it off. Flip the big power source button on the back to off && then on. Then hit the power button on the side, and it should turn on. Worked for mine. Hope it helps.
Aug 31, 2010 | Sabre LCT371BKA LCD TV
TV switched off and lamp is flashing red
you need to buy a new lamp you can order them on line or order from like a Bestbuy,no way around it
May 12, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
LG 37LP1D 37 in. LCD Television Logo
65 people viewed this question
