Maytag performa pavt144aww
For some reason, the machine wont engage or spin after filling up with water.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Lifht the lid up and down and listen carefully . do you hear a clicking noise ??? if not your lid switch is not engaging, unit doesnt think door is down its not going to advance into spin
Posted on Feb 24, 2008
Maytag Performa washer will not spin
Typically when the washing machines wont spin it's off the belt. I havent done this myself, I usually have a technician come out to take care of it.
Apr 16, 2013 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Leaks water when filling up before spin cycle. Does not stop filling up with water
It sounds like your pressure switch tube fell off. You will need to replace your brake assy on the the washer which requires a special brake tool that has to be ordered. You may want to call a tech because the brake tool is like 80 bucks. The reason this occurs is the brake stops too hard and jerks the tub which pulls the tube loose. Hope this helps _MJ_
Jun 09, 2010 | Maytag Performa LAT2500A
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
The machine won't AGITATE and won't stop filling with water. It will spin the water out in spin cycle
sounds like the pressure switch indicating there is a blockage in the pressure system or tube which is located inside the machine.
Mar 31, 2010 | Maytag Performa PAV2200
Maytag Performa model mtw5740tq0: won't fill up with water
There is an exit hose behind your washer, it has to be maintained a particular height (approx 30inches from ground) before it goes into the standpipe in the wall. The gap in the pipe should not be a tight fit. Another thing that could have occurred is that one of the pipes underneath the washer has come loose; you just have to check these things out. But plug off the mains socket first!
Feb 10, 2010 | Maytag MTW5700TQ Top Load Washer
Recently our Maytag Performa washer has started
The transmission might be going bad.
Nov 02, 2009 | Washing Machines
My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
Sep 01, 2009 | Maytag Performa PAV2200
Water fills but won't stop filling-overflows and won't spin out
This is joyce
You might want to check into the Valve that lets the water flow into the machine or it may be the switch that controls the water flow to the machine, it is either one of the 2. go to maytag.com and dowload your document to your machine type and see if you can get help.
let me know how it goes
thanks
joyce
Feb 19, 2009 | Maytag Performa PAV3200
Maytag Performa...It fills up and will not spin.
There are to devices that can cause this. The lid switch and the water level control valve.
Jan 09, 2008 | Maytag Performa PAV3200
Washing Machines Logo
450 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
