Question about Toshiba Satellite P205-S6287 Notebook PC
Shuts down Help - I just bought a Toshiba P205D-s7802 and it shuts down by itself with full battery power and it is plugged in. It worked well the first 2 days I had it and now I it shuts down and runs slow. Would an update on Vista cause this?
  • castindreamz Jul 20, 2008
    while using my toshiba satellite p205d-s7802 laptop it shuts down on its own while being plugged in and on a full battery, the screen goes black but the key board is still with lightsi havent payed attention yet to see if the fan is running or not when it happens due to it happening so unexpectedly and now happening more often, how do i go about cleaning the fan to see if that the problem?
    President:
  • 778 Answers
A Vista Upgrade from XP could cause problems, and even the one you describe, but not an "update" usually. But then again, if when it shuts itself down, if you have to press the power button twice to get it to start back up, I would say that the processor is overheating (in which case the system does this to keep from frying the CPU). If that's the case, a cleaning of the fan and heat sync could fix the problem. You could also run temperature monitoring software (plenty are available for free trials).
As always more detailed information on this issue you are having would help.
Good luck.
Posted on Feb 24, 2008
Installed Programs not Launching - Toshiba Satellite P205D-S7802. OS: Windows Vista
Well both Chrome and open office you can uninstall then reinstall from downloads from the net.
Just make sure you back up your data to a separate medium first.
Jul 02, 2014 | Toshiba Satellite Computers & Internet
Hi, i have somewhat similar problem from one question you have answered below... i used to open my laptop the whole day getting on the net and watching movies.Just as usual night after watching, that i...
yes,you have to open the laptop, and locate small coin sized battery(cmos battery), remove the battery for 1 to 2 minites and put it back . this will reset the bios and it may solve your problem. thank you keep smiling aaarwind
Jan 15, 2011 | Toshiba Satellite P205D-S7802 Notebook
Toshiba Satellite P205D-S7802 lap top, I had lrft it on when i left for a Doctors app, when I got home it was off and no power, is there away to test the different components such as the power plug, power...
Take out the battery and leave out for about 30 sec - to 5 min this will reset some settings for you then I would change my power settings where it never sleeps this is a very common problem.
Chris Thrash
B52Computers
Jan 10, 2011 | Toshiba Satellite P205D-S7802 Notebook
What shoud i do if it doesnt turn on?
Hi Nelitzap
If the system is Not Turning on , You can try a Hard reset
Step 1. Take the battery and power cable OFF the laptop
2. Press and Hold Down the Power button for 1 min
3. Check the with the ac adapter alone if not turning on
4. Check with Battery
5. If system is not turning On you need to repair the Laptop.
Dec 07, 2010 | Toshiba Satellite P205D-S7802 Notebook
I have a Toshiba Satellite, model: P205D-S7802. Laptop works just fine, but I would like to know more about what I have. I found info on the CPU, RAM, vid card but I can't find anywhere what motherboard...
you should use an application, sometimes a use an application named everest, this little application can help you know everything about your laptop components.
Oct 01, 2010 | Toshiba Satellite P205D-S7802 Notebook
Satellite P205d-S7802 I hooked a usb device and the sound for adding a new device sounded then again like it was diconnected and then again and then the computer shut down and when i turn it on youll here...
I want you to try something and i swear I have fixed laptops under these same symptoms.
  1. Pull the battery
  2. pull the HDD
  3. Pull the Ram
I want you to blow out all the ports on your laptop including ram slots and where your hard drive plugin. Leave all of this out for at least ten minutes as so the capacitors can discharge the energy that is in them. Sometimes laptops will incur a power spike and will be unable to release the extra energy and the system shuts itself down almost like self preservation. There are no symptoms that lead up to this. Try this and if the above doesn't work try booting with different RAM and so on once you have exhausted all possible culprits then you can say that the motherboard is bad. keep me update
You could have sent a short through the motherboard . Let me know if this helps
Jan 29, 2010 | Toshiba Satellite P205D-S7802 Notebook
Running high temps
For the best cleaning you should take the laptop to a service. If you open by yoursefl and cleanit you have a good chance to not mountit 100% good. Do not try to use a compressor to blow air on the laptop because you can break the coolers
Jul 14, 2009 | Toshiba Satellite P205D-S7802 Notebook
Toshiba Satellite P205-S6287 Notebook PC Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
