Question about Tricity Bendix AW1000W Front Load Washer
Bendix washer dryer 1054
Drum has stopped turning and spinning. Checked belt, all elctrical plugs in, removed and tested motor - OK and all other functions operating fine - any suggestions.
  • 121 Answers
The brushes need replaced in the motor by the sound of it
Posted on Mar 03, 2008
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Loose Inner Drum on Tricity Bendix AW850W
Has the belt come off the pulley or the motor pulley? If not and it is in good condition has the belt stretched and not connecting properly or the motor slipped making the belt loose? Has the main pulley bolt come loose?
Dec 28, 2012 | Tricity Bendix AW850W Front Load Washer
Dryer drum has become very stiff and won't turn smoothly.
OK, you will need to check the blower and the motor or any blockage. You have have an article of clothing hung in the blower or a dryer sheet on the motor etc... The best way to test the drum, blower and motor is to remove the belt and spin each one individually. Post back the results. I also have the service manual for that unit if you should need it.
Regards,
Richard Roth
http://appliancecafe.com
For all your appliance repair needs
Dec 07, 2012 | Whirlpool LTE5243DQ Combination...
Hi My WD440 washer drier will not go into spin on either fast or slow. I can hear the pump running but thats all that happens. Can you help me. The machine is empty of water and the load is not too heavy....
Remove the rear cover and check the motor drive belt which may be broken or loose. Check the motor and drum pulleys for tightness. Also, verify that the motor turns when it is supposed to. If it doesn't turn, turn it by hand to make sure that it is not bound up--drum or motor. If ok, then either the motor is bad or there is no power to the motor.
Oct 30, 2009 | Hotpoint Aquarius WD640 Front Load...
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Candy CNW156 washer/dryer: spins empty, won't spin under load
If the belt and the motor are OK, then tell your friend to check the motor coupler, the MCU (motor control unit).
See also the following link : It doesn't spin.
Dec 01, 2008 | Candy CNW156 Front Load Washer / Dryer
GE Electric Dryer Older model
it could be the motor capacitor. to check, turn on and carefully give the drum a push in the direction of rotation. if the drum picks up speed and goea ok, then the motor capacitor is faulty. cheap part
Jun 26, 2008 | Dryers
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
WDB1043M Bendix Washer/Dryer
Have you taken the back off the machine? It is relatively simple to do. This happened to ours (exact same model) and there is a brace arm that comes from the right side of the machine (when looking at the back) and it braces the drum. It could have broken off and needs to be welded back in place. We are currently having another issue with our machine that may be a bad motor or a bad circuit board and has once again caused it to stop spinning. The part my husband welded back together is still well attached.
Jan 09, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix AW1000W Front Load Washer Logo
178 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
