Question about Sony PlayStation 2 (PS2) Console
Ps2 the power buttton will not tun system on whats the problem power cable a new and ac adapter too
  • Kyle Porter May 11, 2010
    Is it one of the newer slim PS2's?
  • 50 Answers
There may be a few issues. First off you should contact sony about how much it will cost to get the issue looked at. Or the issue may be an internal cable error which may require light soldering. If this is the case, you can open the system and check for loose or unconnected wires.
Posted on Feb 24, 2008
My laptop not starting up on pressing start buttton.
ensure it's fully charged.
plug in AC
if that doesn't work, plug out ac, remove battery.
hold power button on for 30 seconds
put battery back in, then AC
if that doesn't work, either AC adapter is broken and not charging the PC, or else motherboard is dead.
Nov 11, 2014 | Dell Inspiron 1520 Motherboard
The on/off switch won't turn on. i have power on (red light) switch clicks but no green light. i have taken lid off and white button seams on work but still no green light. i have even held down little...
This is one of three things. Unfortunately, it's difficult to determine which, unless you start replacing parts.
1. Bad switch. The switch doesn't usually go bad by itself, has the PS2 been dropped? Bumped? Anyone push the switch too hard? It's held in by solder on all 4 corners. If the solder becomes dislodged, the switch can fail.
2. Bad cable. This is rare unless someone opened the PS2 and removed/installed the cable a few times and frayed the internal wires.
3. Bad motherboard. Sometimes a power problem can develop, or the motherboard can short out. It's pretty rare, but I have seen it happen.
4. Bad AC adapter. Recent power surge? It's possible that the AC adapter is delivering enough voltage to power the standby light, but not enough to power the actual system on. You can easily check this by plugged your PS2 up on someone else's AC adapter or taking your AC adapter to someone else's PS2.
You can find parts at the following page:
http://store.richspsxparts.com/ve12s.html
Nov 09, 2009 | Sony PlayStation 2 Slimline Console
What do that mean if yor ps2 tuns green then go back red
is it a slim PS2?
did it shock you when you touched the standby button?
if so, just unplug the power cord from the wall and wait a couple minutes before plugging back in.
hope this helps :p
if not, then you might have to replace the power/eject ribbon cable.
maybe someone more knowledgeable has better suggestions?
Oct 18, 2009 | Sony PlayStation 2 (PS2) Console
No screen or any lights when try to tun it on!
Does the AC adapter have a LED on (Either on the adapter brick on on the connector to the system) if not you may have a power issue.
Next, try reseating the cable for the center control cover cable
http://support.dell.com/support/edocs/systems/studio1737/en/SM/centrcnt.htm#wp1179905
Sep 27, 2009 | Dell Studio 1737 Laptop
Inspiron5150 don't come on and I have a blank screen and underscore....
Turn off the system. Remove the battery and AC adapter. Press the power button for 20 seconds.
Put the battery on and try to turn on. If still same problem persists. Put the AC adapter on and tun on the system.
Then try to tun on the system in safe mode by pressing F8.
If this does not help. Try checking for the diagnostic lights in the Num Lock, Caps Lock and Scroll Lock LED's. This will indicate any kind of hardware issue.
Please do comment on the LED's if they are flashing in any pattern.
Try to reseat the Memory and hard drive if possible. This will resolve the issue.
Jul 11, 2009 | Dell Inspiron 5150 Notebook
Will not power on, even when plugged in to good socket
Have you tried resetting the AC adapter? If not, then try this:
  1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
  2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
  3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
Jul 03, 2009 | Nintendo Wii Console
My console will not turn on. It's less than a year old!
Try resetting the AC adapter.
Jul 02, 2009 | Nintendo Wii Console
Wii will not power up. worked one day not the next
Have you tried resetting the AC adapter? If not, then try doing this:
Jun 29, 2009 | Nintendo Wii Console
My ps2 does'nt turn on when it's plugged on!!!!
Hey man, I had the same problem a few weeks ago, but not anymore! What's wrong is that a cable inside has become unattached, this cable controls the front buttons. What I did was open up the top of my PS2 and check the cable,(it should look like a strip of paper) if it is unattached then you have some work to do. Flip the Ps2 over and open the bottom up. You should see the motherboard and lots of other stuff. Ignore it. What you want is a small port on the side of the front buttons cleverly hidden under a metal box thingy. Plug the end of the cable in to the port. On my Ps2 it din not stay in, so I had the Ps2 on and wiggled the cable until both front lights light up. Then you need to fasten the cable down in the right position. I used Scotch tape, but you can use whatever you want, just as long as it holds it down IN A POSITION WHERE ALL LIGHTS LIGHT UP! If this does not work, then I got nothing, hope this helps! Here is a you tube video that might help!
Apr 27, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
