Question about Envision EN-9250 19" Flat Panel LCD Monitor
No power to monitor.
Monitor will not come on at all. No green light... nothing. Pushing power switch repeatedly does nothing. Have replaced power cord... no change. Is there a fuse in there somewhere?
    Problem Solver:
  • 18 Answers
Do you check the fuse? and check all of your capacitors.
Posted on Aug 14, 2009
  • 3 Answers
The problem can be solved by replacing the power supply board. Only problem is finding the part.
Posted on Dec 24, 2008
    Guru:
  • 147 Answers
Hello mousemilk,
The monitor itself is defective and can be either:
1) Replaced under warranty
-OR-
2) Repaired at a local shop. If this is the case and you are NOT under warranty - the best solution is to buy a new monitor.
Take care!
Posted on Feb 24, 2008
  • Alexander Kogl Feb 27, 2008
    Mouse,
    Has the solution helped?
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Green light is not on in front of CPU. Monitor shows nothing!
ok memeory problem
try another chip and see..
Nov 14, 2009 | Intel Motherboard
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Envision Monitor 22", when plug in the power core, the Green power light would blink repeatedly non stop. Screen would show nothing just a blank screen... it a one year old monitor, and was working fine...
Hi, when connected to a portable you sometime must hold function key then press F5 or F6 to switch between the portable screen and the aux monitor, have you tried the monitor with another computer. If this does not work, it might require internal repairs...
Aug 13, 2009 | Computers & Internet
Dell 17" Monitor - Won't display anything, power light flashes
Akeru, It may or may not show up again. My guess is that it will. This seems like a power supply/inverter/CCF tube issue. The lamps try to fire up but due to a possible fault in the Switch-Mode-Power-Supply and or the Inverter circuit the SMPS goes into shutdown and does a self reset after 5 seconds. And then repeats the whole cycle again. Well if the unit is over 5years old you can do several things. 1. See if DELL can do a swapout. Send your's+$40-$90 to them. They send you a same model REFURBISHED (new CCF tubes/inverter/smps) and a short 30day min warranty. 2. You can locate a electronics repair shop ( TV/VCR/DVD/Monitor) that knows all about cold cathode fluorescent tubes and their power source, Inverter type. 3. Try to effect repair on your own. That's about all the options that a consumer/user has open to them. I'm louie12fix on fixya or lmistyrel@ aim.com Bye for now.
Apr 30, 2009 | Dell E173FP 17" LCD Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Jun 02, 2008 | NEC MultiSync 1550V 15" LCD Monitor
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Envision EN-9250 19" Flat Panel LCD Monitor Logo
193 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
