Question about Dell 1600n All-In-One Laser Printer
Open Door Error - Open Heat Error
I was trying to help out our local pastor with his 1600n MFP for the open heat error, so it took it apart hoping to find some physical evidence of a break or something. In the process, a small part which is likely the "Open Door" switch part creating the error fell out on its own. Here'a couple of pictures. Just where does it go, I couldn't after two hours figure it out or find any diagrams online anywhere. The "open heat" error probably posts after this but I won't know until I clear this one. Thanks, Dick
  • wasput May 22, 2008
    when i put the printer on it says open heat error
    Scholar:
  • 105 Answers
That looks like part of the heating element itself. You need to remove the four screws on the back door, then remove the door so you can have access to the fuser module. There is a black module about 8 inches across that has a heat warning on it and two sets of wires coming out. With printer unplugged and face down, unhook each wire set and locate the four screws that hold it in place. Remove them, then pull the module up and out. On either side of the module you will see where the wires connect to a long thin metal plate that runs through a rolling mechanism. In all likelihood, if the element on the fuser is broken you will need to order a new one. Installation is simple -- reverse my instructions for disassembly (Dell can send you the new part--just call Dell parts and service to order).
Posted on Mar 27, 2008
I have an open heat error on my Dell Laser MFP 1600n, can you help ?
Heat errors are usually caused by the fuser (part# N5796). ItemInc.com has this in stock and ships same day for $99. Installation should be pretty simple. On most Dells, the fuser is located on the back of the machine, open the rear door and it is usually held in by 4 screws. Good luck, and thanks for using FixYa!
Sep 13, 2011 | Dell 1600n All-In-One Laser Printer
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
The display reads open heat error. What is this and how can i fix it? I do not know where the manual is.
An open heat error on a 1600n printer is a fuser error. You would want to make sure that the printer is not plugged into a UPS or power stripe. You would also want to make sure that there is plenty of clearance around the printer. If these are already in place then the fuser would need to be replaced. This is not normally a customer replacable item.
Aug 07, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1600n error - What does "open heat error" mean
1. Please check the thermostat in the fixing unit.
2. It may open due to over heat. replace it. clean thermister.if spoiled replace it also.
Jul 15, 2010 | Dell 1600n All-In-One Laser Printer
How do I repair an "open heat error"?
I'm sure it's not the answer you're looking for but the "Open Heat" error is related to the printer's fuser, switch mode power supply or temperature control thermistor. More than likely it's the fuser which needs replacing and you'd need to contact Dell for a replacement. If you google for "1600n fuser" you'll also come up with several retailers with fusers in the $80 range as opposed to Dell's $140+.
Jan 21, 2010 | Dell 1600n All-In-One Laser Printer
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Feb 22, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
613 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
