Question about HP PhotoSmart 7150 InkJet Printer
Carriage stuck My HP Photosmart 7150 wont work when you go to print the carriage goes all the way to the left but stays stuck it wont return.I open the doorand it works fine,so I close the door and try to print and gets stuck again please help its very frustrating. Thank you
  • Anonymous Jun 13, 2008
    net carriage is stuck
  • 152 Answers
Change "encoder strip"
Posted on Feb 28, 2008
Hp photosmart 7150 makes ratcheting sound when head resets
With the power off, open the cartridge compartment and move the carriage fully from one side to the other and back to where it started.
If that doesn't fix it, open the compartment with the power on, and after it centres, move it to the left and the right and back to centre.
Jan 19, 2016 | HP PhotoSmart Office Equipment & Supplies
Ink cartridge jam
Try cleaning the carriage bar. This is a shiny rod that the ink carriage slides back and forth on. Wipe it off with a clean rag and put a drop or two of light oil on the rod. The carriage should move easily back and forth.
May 01, 2017 | HP Photosmart C5280 InkJet Printer
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
HP Photosmart C3180 carriage permanently stuck on right. How to fix this?
If the carriage totally stuck on the right side of the printer, Unplug the printer from Power outlet.
Open the front access door. You will see the cartridges. Remove the cartridges. Check for any paper stuck in the Carriage Rod. Try to manually move the carriage 5-6 times left to right and it should move without any trouble. Put the cartridges back into the Cartridge slot and power on the printer
If the Carriage does not move manually, there could be chances the printer needs mechanical repair as its broken.
Regards,
Sean
Sep 16, 2012 | HP Photosmart C3180 All-In-One InkJet...
My printer prints triple everything photosmart 7150
In the properties of the printer on your computer, you probably have it set to 3 copies. Go to devices and printers and open up the printer properties. Probably under the "advanced tab" you will find a setting for number of copies. Let me know if you are having problems finding the printer properties.
Jan 21, 2010 | HP PhotoSmart 7150 InkJet Printer
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
Only prints on one side
Hi, You have to remove the Catdriges from the printer and clean both catdriges and the roller. This might sort your problem. Secondly before printing check the pagesetup of the particular file.
Mar 09, 2009 | HP PhotoSmart 7150 InkJet Printer
Error code
I'm not able to post a link, but go to the HP homepage and click on the support and troubleshooting link, click on the "all in one" link, click on the "solve a problem" link, click on "errors and lights", click on
Aug 24, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP PhotoSmart 7150 InkJet Printer Logo
212 people viewed this question
Seeker5211
Seeker5211
