Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Blue color problem
I would just add to my tv problem. picture is not distorted, the blue color is arching and it becomes a shadow. in manual convergence you can't move it but the red color can be moved.
  • magisis Mar 10, 2008
    fuzzy blue when doing perfect focus, all other colors are sharp. Blue shadowing. Have the 2 STK392-040 package
Same here, fuzzy blue when trying perfect focus, all other colors are sharp. I have the 2 STK392-040 package
Posted on Mar 10, 2008
I have a 8 year old 57in Sony projection HDTV,when the picture is dark you can see faint blue lines in a curved arch like pattern across the screen.Any ideas? Thanks
The tv problems is call a convergence picture problems,it is just starting to developing.This problems when it is fully developing into a convergence picture problems to the tv eventually.Tv will develope into a colors lines R,G,B mis alignments,have a colors shadow pictures or into a picture 3D look alike.Eventually the tv convergence board will dies,have to have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.This problems the tvs shops will cost u like $300-350 for parts and lobors.
Aug 13, 2011 | Sony KP-57WS500 57" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
The 3 colors are off, i have shadows and arches in the screen
It is failure of convergence ICs and these two ICs will be replaced on D board.
If you are comfortable with TV repair and know good soldering skills then can do the job easily.
Convergence ICs are mounted with sliver heat-sink on D Board of TV and part number will start with letter STK...
Get back to me if you need further info.
Jan 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Sounds like a convergence IC problem, you will need to replace them'
Heres a quide
see the before and after pictures to verify your problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 15, 2008 | Televison & Video
Color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
130 people viewed this question
Jerry Greenberg
Jerry Greenberg
