Question about Cobra 148 GTL 120-Channels Base CB Radio
No modulation lots of signal
Radio was working great i changed antanas and a "freind" said i should tune it up while it was out, so i let him mess with it, now it has great signal on key up butt extreamly weak modulation is there a way i can turn it back up on my own? i dont want to go back to him and hurt his fealings or risk messing something else up.
  • 3 Answers
It sounds to me if im understanding you correctly, that your friend turned up your carrier? correct? and now the radio isnt as loud? If what im saying is right just turn your carrier back down.
Rollins is correct... but seldom do people have o-scopes and internal precision counters and rf probes. depending on what your friend did .. you may or may not have to send this radio to someone that has a working knowledge of alignment of radios. just remember its woth the little bit of money to have someone that "fixes" radios tune your radio. good luck .. Rick
Posted on Jan 30, 2009
  • 126 Answers
It really depends on what he messed with while he was inside the radio. If he accidentally turned down the rf output power, you can use an inline rf meter and then tune L37 and L38 for max rf output.
Dean
Rollin CBs
Posted on Feb 24, 2008
  • Dean Pitts
    Dean Pitts Feb 24, 2008
    That is the quick and dirty way to turn it back up. The only other way really to do it is to download the factory service manual, from cbtricks.com, and then re-align the radio by the factory specs, with the proper test equipment.
Meter drops when pushing mic
some one tuned their radio to the wrong side of peak and now you have downward modulation .Try re-tuning it back to to its original settings and if you get it back don't mess with it unless you know what the shell you are doing.
Sep 30, 2012 | Cobra 25 LTD 40-channel Classic CB Radio...
Hi i recently bought a cobra 29 ltd chrome cb radio for my car,i also installed a new antenna ,i have a strong signal,but i am unable to hear conversations because the sound is distorted.It sounds like...
You can't tune the radio. You are supposed to tune the antenna.
I have a page for tuning your antenna. This can cause some distortion, but it shouldn't be that bad. Go here for how to tune your antenna.
also the internal speakers aren't that great. Try an external. I can't just use an internal because an external is so much better.
Something else to consider. There is a lot of skip right now. Skip is when the ionosphere becomes charge by solar flairs, and causes radio signals to skip across it, making them travel hundreds and even thousands of miles. There are some cb operators out there who run a lot of power. 10k watts and up, who just talk skip all day. A lot of those guys sound extremely distorted and over modulated. You may be hearing these guys out there. Its their radio's not your receive.
Also. People who are close to you, may over load the front of the radio in the receive section, which will make it sound distorted.
Aug 16, 2010 | Cobra 29 LTD CB Radio
I have a super star ss148egk built on cobra chasis and cant get any modulation swing. ON am dead key 4 watts no more and would like to be able to get out a little better.
Hi rcstss, I would search youtube for that radio, in searching include the word "Mods", if you feel comfortable opening up the case, make sure you have the proper tools handy. Such as a set of "Plastic Tuneing Tools, also a Watt Meter with SWR, and Modulation on it. Also, a Dummy load for the freguencies that it will cover! You would not like to interfere with your freinds. There are a LOT of Mods for that radio.! Or try and find some shop that you can TRUST! It really sounds like a simple problem to fix, but I'm an Old Ham, and it just second nature to me. And I have more equipment than I really have room for! Good Luck, I bet you will find the answer on youtube though! 73, Collin..
Aug 14, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
My jvc lcd does not work with my local air tv, i get weak signals
Ur tv is getting a free air DTV right?Not Cable tv,Satalite or Telicom compannies services?Yes,than.Get a better antana like a roof antana or Digital inside antana to get better stronger and longer ranges to recieve the signal.Go to ur tv Menu.Goto setup Ch. Pick AIR rescan all the free DTV signal again,u should get all channel and a strong signal.
Jul 29, 2010 | JVC LT-32E478 TV
Tuning drifts
It sounds like the tuner is out of alignment. A number of things can cause this kind of problem. However, a realignment is a very costly proposition, especially when considering the used value of the Proton 320. If you really like this radio, you might want to try buying a used example off of eBay. They come up very frequently. Only... be selective. Don't pick anything from a seller without a lot of good feedback. And don't overpay ($50 tops).
May 08, 2010 | Proton R5A Clock Radio
I just purchased a connex 3400hp and my cb freinds tell me that my other radio sounds better than the cx 3400hp,my other radio is a cobra 29 ltd classic.my 29 has more audio and modulation and both radios...
The Cobra 29 has always been a good talking radio and is preferred by truck driver mainly for that reason! The Connex is a great radio in it's own right but sometimes needs a little help. I would suggest a power mic and there are many to choose from but Astatic is a clear winner! My two cents for a suggestion!
Mar 07, 2010 | Connex 3300 240-Channels Base CB Radio
Bose radio awrc1g only static like there is no antana. Works some times. CD works fine.
Mine did the same thing. I took the cover off and took the radio apart. I discovered the FM/AM tuning crystal was separated from the mother board (soldering failed). Anyway, when figured out where the crystal went I reinserted it and it worked great. I considered gluing it back in but opted to test my soldering skills and it worked out just fine. The crystal is a small silver electrical component with 2 prongs that plug into the motherboard.
Good Luck.
Oct 20, 2009 | Bose Wave Radio
Radio signal strength not very good
It is due to the vehicle antana. you need to purchase a antana booster. hook it to a 12v power plug antana from car to one side of booster and radio to other side. this will increase signal from car antana to radio and should fix problem. most boosters can be found at any car audio or truck stop and run from$10.00 - $25.00 good luck
May 21, 2009 | Goodmans CD car radio GCE358MPT CD Player
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Cobra NW LTD CB radio
start out by getting a good antenna like a wilson or k-40 if your using it on a big rig make sure its a metal mirror and door a lot of big rigs use fiberglass and thats a nono you must get a no ground plane antenna...its all in the antenna...good luck doc's cb shop ny
Apr 09, 2008 | Cobra 29 NW CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
126 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
