Question about ADI Corporation MicroScan 5P (White) 17" CRT Monitor
ADI monitor , model 937g, power supply dead , fuse is ok ,what could be the problem ?
    New Friend:
  • 66 Answers
Replace 100uF/63V condesator and check transistor
BUT12AF if this is ok? check resistor 470k ohm and 1.2M ohm if the value is correct
Posted on Feb 13, 2010
SOURCE:
Aple HD Cinema Display 23" is dead, no front LED light or back display light
Contact Apple support by phone 1 (800) 204-4427 US toll-free or chat, set up a repair, or make a Genius Bar appointment for iPhone, iPad Apple Mac Technical Support Phone Number 1 800 204 4427
Jun 14, 2017 | Apple Cinema Display 23" HD Monitor
Iiyama E2607WS just stopped working - completely dead - internal fuse OK
In most cases there are one or two capacitors in the power supply that open, and in some situations they have a bulge at the top making it easier to spot.
Apr 19, 2012 | iiyama E2607WS 26 inch Monitor
My scepter e240 wont power on is it junk or what
dear,
first of all, check whether the power on/off button light (LED) turns on or not. If it goes on either orange or yellow/green, it means its not completely dead. If its not doing that then its a different matter.
Then you have to check the power cord that can be problematic and need replacement. If it is ok then you have to disassemble your monitor to check the inner fuse that is related with the power supply.
Most probably it is cause by the Capacitor, if it is dead and after checking the fuse!
best of luck!
Mar 31, 2012 | Sceptre X5g-Komodo VII 15'' LCD Monitor
I have a monitor samsung and no power on it I check the fuse its ok and i found a power on power circuits what i can do
go to authorized personnel...don't try to do it by urself..
it contains more than 25000volt at EHT & power supply is most complicated circuit of monitor, so don't try it.
Aug 23, 2010 | SAMTRON 55V 15" CRT Monitor
Viewsonic VP2030b LCD monitor - No power
There should be one fuse in the power supply inside. You can check and replace that if its dead. now if its not dead and you got power to that point you do need to rule out any capcitors at that time but if the fuse is gone it will not hurt to check the rest of the supply for the fault.
Please rate and accept the answer if it did help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 18, 2009 | ViewSonic VP2000s 20.1" Flat Panel LCD...
Westinghouse L2410NM monitor dead
What about the fuse? Sometimes there is a fuse on the circuit board.
Jul 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
My monitor stopped working
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Feb 16, 2008 | ViewSonic VE175b 17" LCD Monitor
No power to monitor
Your problem is really multiple problems. One is if the monitor blew out, the second is weather it damaged the computer when it went, the third is if the computer went first killin the monitor. I would first see if your computer is ok by turning it on with out any monitor connected and listen to hear if it sounds as usual. If not something may be wrong with your computer. If everything is ok plug in another monitor (borrow from a freind if you do not have a spare) and see that the computer is ok. If it's ok great but if there is a problem with the computer that is a whole new question.Next if the monitor's on light does not come on and you know it has power the monitor is most likely fried. Hope this helps and could use more details
Dec 29, 2006 | NEC MultiSync LCD1550ME (Black) 15" LCD...
ADI Corporation MicroScan 5P (White) 17" CRT Monitor Logo
148 people viewed this question
Top ADI Corporation Computers & Internet Experts
Ekse
Alun Cox
Are you an ADI Corporation Computer and Internet Expert? Answer questions, earn points and help others
