Question about Samsung HCM4216W 42" Rear Projection Television
Samsung hcm4216 projection tv blue color problem
My tv has this kind of problem every year for 4 yrs and every time they change the convergence chips. this yr my warranty has expired and i have to do it myself. i replaced the chips but i still have the blue shadow. the picture looks ok except the blue shadow.
  • Vallen Apr 07, 2008
    I just have the same problem last week. I bought it 4 years ago. Everything works fine but the blue shadow. See anyone can help us with the part# and the service manual, thank you.
I have samsung tv it run very properly but after 1 hours the screen become green the sound but the picture does not show, the tv mechnic is telling that there is problem in picture tube.
Posted on Feb 18, 2010
I had the same problem 2 years ago. The best solution is the simplest solution if not the cheapest. Just change the whole convergence module for an updated one(sorry can't remember the model number). It will cost about 130$ but it will solve the problem for good. The original IC's run hot and burn out the updated one has a higher resistance.
Posted on Apr 03, 2008
  • 2,326 Answers
I would suggest to inspect the solder joints again carefully. If the solder joints are fine, check for the low values resistors and fuse resistors around the ICs using an ohmeter and also the solder joints for crystallized conditions.
Good Luck.
Posted on Feb 24, 2008
  • 520 Answers
First of all in setup mode(where convergence is)select blue screen off.then go to picture mode and either select a set mode,or enter user and manually set contrast,brightness,colour,sharpness and tint.you can acheive near hd quality this way on non hd projtv
Have samsung hcm4216 w/ model code hcm4216wx/xaa that has convergence problemn would like to know correct current complete convergence board part and where i could purchase( I need to simply be able to...
Try Partsstore.com for a whole board...
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 25, 2011 | Samsung HCM4216W 42" Rear Projection...
Blue is not aligned and when i do the magic focus it gets stuck on the blue and a 4 appears on the bottom right corner
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 26, 2011 | Hitachi 51F500 51" Rear Projection...
Experiencing convergance problems in upper left hand corner on Samsung PCL541R mostly red shifted to right and down Bottom right half of screen is clear Do I need to replacer convergance chips?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | Samsung PCL541R 54" Rear Projection...
Just got this t.v from my dad. It is a pt5492 model. It has kind of dark yellow picture with alot of red. He was told it might be blue light is bad? Can I fix this myself?
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 16, 2011 | Akai PT5492S 54" Rear Projection...
The color is bad on my projection television, I want to know how to adjust the lens.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 15, 2011 | Samsung HCL473W 47" Rear Projection...
Picture has a problem lost a lot of the color
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
My samsung HCM4216W TV has 3-D effect i was told it is a conversion module for the bulbs is this right
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 12, 2011 | Samsung HCM4216W 42" Rear Projection...
Last night we got some multicolor, green, yellow etc horizontal, kind of half moon shapes coming across the screen, removed the front screen and cleaned the lens's and mirror,, no change. Any Ideas?...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 01, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung hcm4216 rear projection
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
1,170 people viewed this question
Henry  Thomas
Henry Thomas
