Question about Toshiba MD20F51 20 in. TV/DVD Combo
IMAGE IS ZOOMED ON SCREEN
IMAGE IS ZOOMED AND PICTURE IS CUT OFF.
  • livestrong Feb 24, 2008
    hi we dont have that optio.. any other suggestions :(
Is there a zoom button to the left of the channel down button on the remote? Press it to toggle, it may be in 3 steps. Its on my Toshiba remote. Maybe only for DVD though.
Posted on Feb 24, 2008
  • 593 Answers
Use the format button, might be called screen size. You are looking at a format that the screen cannot show completely, I can cut the top and bottom off or make it widescreen and lose the edges on my TV
M camera is ways zoomed in. I have Aspire E3-111
Take the mouse to the left hand edge. You will be given some options in a black band at the bottom of the screen.
One of these is CROP, which you can use to reduce the size of the picture.
Mar 01, 2015 | Acer Computers & Internet
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
My picture is zoomed in. Cannot go back to 'normal' and see everything. Credit names, etc are cut off on both sides.
Hi
Thanks for using FixYa. First of all please check your cable box settings first. Sometimes the remotes have a picture size button on them, and someone might have pressed that by accident. Check the TV settings, press Menu Button & then go to Window/Image size. Now select Full Size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 26, 2009 | Sharp LC46SB57UN 46 in. LCD HDTV
Zooming in
Unfortunately the image is not able to be saved if you have zoomed in on it. The camera does not have the ability to save images that way. You can download the image and use photo editing software to cause that zoomed in effect to happen so that you are able to print the image that way.
Jan 19, 2009 | Olympus FE-210 Digital Camera
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 16, 2017 | Mito Car Audio & Video
Screen Picture is Cut off
did you try pushing the input key on your remote it might change the screen if that don't work then try to go in to the settings in the remote
Nov 09, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Zoomed screen on my TV
with remote control use Zoom boton, or enter to menu and seek for this option.
Oct 23, 2008 | Televison & Video
Screen is to big
Either the TV or the cable/satellite receiver has Zoomed in to the image when parts of the picture are cut off. Look at both remotes for a Zoom feature or the onscreen menu's for any settings. Usually TV settings don't change on their own but cable/satellite receivers can receive updates and it may need to be reset afterwords, much like a PC.
Oct 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba MD20F51 20 in. TV/DVD Combo Logo
273 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
