Mitsubishi WS-55807 We just acquired this TV and got it to work -- sorta.. But the pit'cher sucks big time -- is in Black and White for the most part.. Last night, the first time we tried to hook it up and all, we got it this far.. Today we went to Best Buys and the guy there said it was definitely the single cable 'In' to the Dish box.. He said I needed these triple wires -- Red, Blue and Green and all would look good.. Well, I hooked these babies up but I'm not sure about Where I hooked them up or anything but it did nothing.. I hooked up another triple wire set I had previously for VCR hookup and mabye that did something right as we now have the sucky picture just like last night.. HELP!!!!! Please!!
  • 2 more comments
  • Rich Rich Feb 24, 2008
    Thank You so much for your quick response!!
    No, I haven't bothered with the color yet.. I'm still trying to figure out the cable and/or setting problems.. The picture has black lines thru everything.. In other words, the 30+ ? lines of resolution have black lines between the 'normal' ones.. If, for instance, there were a white billboard on tv, you'd readily see the black lines going down the screen fast too.. Make sense??
    Thanx again, Rich
    Easy now!! Your talking to a guy that doesn't know NTSC from PAL..
    I'm in N. Nevada, USofA. TV was broken and given to me this week. $325.00 fixed it.. No, Dish box is not HD..
  • Robert Johnson May 11, 2010
    that almost sounds like a compatability issue (NTSC to PAL). where are you located (USA or other)? where did you purchase it from? is the Dish box an HD box?
    have you adjusted the color in the video settings? use the remote press the video button until you reach color settings adjust with the curser buttons on the remote.
    Sergeant:
  • 395 Answers
Ok, I had to ask, this sight is world wide and the formates of different countries are not compatible for instance the US uses NTSC and will soon change to ATSC while europe uses PAL formate. I could get into it further but we need not since your here in the US. the problem with the set is hard to determine this is not a simple hook up problem. it you receive this problem thru the cable input from the channel 3 of the tv we must issolate if the problem is from the dish box or the tv. 1st hook up a DVD player using the yellow, red, white cables to any input. does the picture improve? if so the dish box is at fault. if not the set has an internal problem.2nd from a blank input press menu is the colors of the menu ok? if it is then problem lies between the input section of the set and the Y/C jungle IC inside never the less you will need further repairs to the unit. send me a picture of the problem (send one with a blank input and one with a signal) treborj37@hotmail.com I will try to assist you further.
Posted on Feb 25, 2008
I have a Mitsubishi WS-55807 and the colors started to separate - you can reset it by turning if off and on again and it goes away but in time returns, starts getting blury then the colors split up - just...
your convergence circuit has started giving trouble .... normal thing after a few years running for projection televisions ...... could be that the convergence IC's are getting too hot (two big IC's on a heast sink bearing an STK number on it) or that you have some loose soldering that needs to be resoldered on them.... worth the check
May 19, 2009 | Mitsubishi WS-55807 TV
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Tv doesn't come on
Mitsubishi WS-55807 Manual
I think that the solution that you are seeking is on page 63 of the manual.
Feb 12, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 turns on but then powers back down after a few seconds
Good Day;
The fuses tell you that circuit has failed and was drawing too much current. No other test is needed.
Good Luck, big Irish.
Sep 04, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807
Good Day, betsy;
Check all cables and try to reset by un[plugging for 3 to 5 minutes(from wall), plug back into wall.
Good Luck, big IRISH.
Jul 28, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807
Good Day, Bocinga;
I hope you solved this concern by this time but if you have not;
Your TV is experiencing a convergence problem.
If you are not a tech type, call an authorized service center and have them give you an estimate.
Jun 15, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807 Corroded Board
generally the attack on paper & wire like speaker & that can be replaced. as per other things like wire is concern as you have told that tv is working, can be changed. tha pcb which has some short of corrosion can be cleaned by pure petrol & it will run fine.this is just advice now it is up to you. for original misubishi you can contact company. & for other board is concern you can get at any tv spare parts shop. hope this will help.
Oct 07, 2007 | Mitsubishi WS-55807 TV
Corroded Board
The best place for board repair or replace is PTS 1-800-844-7871 Yes you would need to fill the CRT's fluid level back up. The liquid is Glycnol(Liquid anti-freeze) Poisonious yes is swallowed! So take precautions. You can get if from places like MCM electronics, Tritronics, bluestar-online.com, etc. It's called CRT coolant fluid. Yes and you would need to fix leak, probably a gasket or seal. Hope this helps!
Sep 14, 2007 | Mitsubishi WS-55807 TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
