Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover floor mate stopped picking up the water
It's been used for two years but now doesn't suck up the water rendering it useless. I've taken it apart to look for clogs but nothing. Suggestions?
  • 6 more comments
  • Anonymous Apr 15, 2008
    Used for less than two months. Will not suction water. Took everything apart but can not see a problem.
  • Anonymous Apr 16, 2008
    There is no suction on the
  • Anonymous May 21, 2008
    this is my second floormate. the first one worked wonderfull for 4 years. Have had this one since xmas this year and the wet vacuum has never worked very well and now won't work at all. Have tried removing tank and reconnecting to make sure it is in tight,Not sure what else to try.
  • Anonymous May 22, 2008
    The floormate worked well when we first purchased it, but the suction has diminished over time, to the point now that, not only does it not pick up the wet solution, it does not pick up dry dirt either. I've checked for clogs, there are none. I've cleaned the filter and checked to make sure the recovery tank is properly installed, but it still does not pick up. I think it has something to do with the hose.???
  • jdmingioni Dec 14, 2008
    We have the same problem. I can't find anything wrong. There are no clogs. The uptake canister is sitting properly in it's place and the filter looks OK as well.
  • Anonymous Dec 21, 2008
    At first my floormate did ok. As time went on floormate doesn't pick up much water, leaving cleaning solution on floor.
  • Anonymous Dec 28, 2008
    I have same problem--does not pick up water. Have taken apart and cleaned. Still does not work.
  • gaucho_qro May 11, 2009
    Where I can find to buy the replacement rubber to the brush on the bottom ? I notice the rubber that involves the suction in ripped and is not working properly, them I have lots of water left on the flloor. If anyone know please send me a answer.
The Tank recovery hose is very easy to remove. With the tank off, there are two screws holding the flat plastic piece that is attached to the hose. A few clips are on each side which just needs to be squeezed together to get loose. The hose unscrews from head and this plastic piece (the wire in the hose acts as threads). I have the same issue with a torn hose, but have not been able to find one locally in Dallas.
Posted on Apr 24, 2009
    President:
  • 1,673 Answers
Usually when this happens, it has to do with a dirty or bad filter(#45, 40112050). Or the recovery tank isn't seating like it should. Maybe this picture will help.
Posted on Feb 28, 2008
I bet the suction hose is cracked. It's a plastic hose. My Floormate was not picking up the water. Lo and behold, there's a hose has split into two pieces.
Posted on Jan 11, 2009
Where is the picture? Can you repost. Thanks
Posted on Jun 06, 2008
The same thing happened to me and I noticed that the uptake hose cracked and I ordered
a part online (only $9.95) however, can't figure out how to take the unit apart to replace the part
so if anyone has replaced it let us know.
Posted on Apr 12, 2009
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My hoover max extract dual v stopped sucking up the water on just its second use. Any ideas on how to fix this problem?
The most likely problem is there is a restriction somewhere or a suction leak. Check to make sure you have good suction where the waste water tank fits down onto the machine. Make sure the lid is on the waste water tank and follow the flow of suction from the machine through the waste tank down to the floor and look for debris clogs or any area where there may be a suction leak. If you have good suction coming from the machine the problem has to be somewhere between there and where the water is being sucked off of the floor.
Oct 24, 2013 | Hoover MaxExtract Dual V Carpet Cleaner...
Will not dry or suck up water at all...BRAND NEW
If it's brand new your best bet might be taking it to a Hoover service center. That'll have a year warranty on it so the fix would be free.
Apr 06, 2013 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Hoover floor mate sucks up water while in the wash position
They do that. They pickup the water in all stages but lower the squeegee to different heights. At no point does the suction turn off.
Jan 20, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floor mate is not sucking up water, why?
First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Parts
http://www.usavacuum.com/category-s/85.htm
Feb 23, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate stopped vacuming water
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Sep 26, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Our Hoover floor mate won't **** up the water. Motor runs but pick up is limited.
you will need to replace the squeege that is located on the nozzle. 3 screws will take it off. you can get this at a vac shop or order it from the company, filter may also need to be changed
Jul 18, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
No suction
I used a new Hoover Spin ScrubSteam Vac the first time and it worked great. The next day it would not such up the water and sounded like it was sucking air. I took off the lid on the recovery tank and when carefully inspecting the gaskets saw a every so small slilt in the small gasket that surrounds the intake duct. I put some silicone glue on it to close and seal it. This morning I tried sucking up water on a tile floor and it worked OK! I have not tried it again on carpets but am keeping my fingers crossed.
Jan 06, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Won't suck up water from floor
1. Check all the tubes from the nozzle to the collection tank and make sure they are not clogged up. I've had tht happen pretty bad before. 2. Check the squeegee. If it is damaged or torn, replace it.
Aug 27, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
5,079 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
