Question about Palm Treo 650 Handheld
Outlook Calendar synchronization failed in palm treo 650
Outlook Calendar synchronization failed when trying to sync my palm treo (Rogers) with my PC ( windows XP)
  • 2 more comments
  • jimmy101 Feb 24, 2008
    2003
  • rabbimark Mar 03, 2008
    when I enter an appointment on desktop, after hotsync, does not always find its way to my Treo.
    Also, sometimes appointments "disappear".
  • jkat08 Mar 06, 2008
    my treo was inpropperly synced because the email adress wasn't deleted before i synced it. I brought it to the verizon store and they said they couldnt help, but if anyone else knows what i can do, it would be great.
    Thanks
  • junior franco May 11, 2010
    What outlook Version do you have?
    Guru:
  • 377 Answers
Hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Posted on Mar 26, 2008
Treo 650 is not syncing with outlook calendar, but syncing with everything else.
You may have tried Exchange ActiveSync in VersaMail When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo. So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Sep 12, 2005 | Palm Treo 650 Handheld
Outlook 2000 Calendar won't synch to Treo 650
goto kb.palmone.com and search by solution id: 31167 for olerr! That is about 1 1/2 hr of troubleshooting to do so: Good luck!
Treo 650 won't sync with Outlook calender on my Windows XP Pro desktop?
I was tring all the possible ways to resolve the issue. At last got a solution for my problem. Hope this will work for you all. Download the "OutlookConduitUpdater.zip" and install. This will resolve the calender "do nothing" while sync.
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Was there another solution?
I tried the conduit updater with no success--I wouldnt bother doing it.
Treo 650 (cingular) and Outlook calendar
Its the substandard conduits that come with the 650. Hi - my issues were different than yours,but similar in that bottom line, my calendar data wasn't syncing correctly with Outlook. I've been dealing with this problem for the past 4 weeks. Sprint's technical support was useless, as was palmone. For 5 years, I have successfully synced my Palm Smart phone to palm desktop at home, and outlook at work - (4 different phones, 4 different companies). It dawned on me - for the past 4 palm devices, I was provided Chapura conduits... The 650 didn't come with them... GUESS WHAT. I bought Chapura Professional XT and all the issues I was having (they were too copious and too weird to go into here) were solved, in one measly synchronization. ALL of them. Don't wast ANY more of your time... Navigate over to Chapura's website and get one of the conduit programs -= trust me... You'll be glad you did.
Sep 11, 2005 | Palm Treo 650 Handheld
Calendar Sync issues with Treo 650
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
How Do I hotsync w/Outlook
what software did you download for your outlook conduits? the installation cd already has the outlook conduits you need.. you just have to install palm desktop first then you'll be given options whether to sync your handheld with palm desktop or with outlook. choose sync with outlook
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Sep 07, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
198 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
