Question about Peavey PVM 22 Microphone
No sound I can not get my PVM-22 to amplify my voice unless I am holding where the cable enters the PA and where it enters the microphone, respectively. It's like I need to make the current go through myself to get any sound... Also, I have a XLR to High Impedence microphone cable, if that's useful information.
  • 682 Answers
You must change your microphone cabel with new  good brand.
Posted on Mar 05, 2008
My pa system recieves signal but wont send any sound out
Check cables to speakers from amp if any. Possible crossover or channel failure.
Apr 08, 2014 | Audio Players & Recorders
It went completely dead. No hum or sound or anything! Can I take it apart-- ?
If you unscrew the headshell you could test the resistance of the coil with a multimeter to see if the coil has gone.
Sep 22, 2011 | Peavey PVM 22 Microphone
I have two JBL speakers each 100W and 400W(peak) connected to sony receiver 7 ch each suppoert 110W connect to Karoak with 2 microphones but to sing souunded not good. thinking to get this 250 W PA amp or...
You haven't sufficiently defined what is wrong. "Not good" is subjective. Before you shell out for different hardware you should pinpoint the problem.
The source (you, mics) and the speakers are the most obvious sources of sound quality issues. Properly functioning amplifiers operated within their limits produce effectively undetectable differences in the sound.
Feedback from the speakers to the mics will sound awful.
Jul 07, 2011 | Radio Shack 250 Watt PA Amplifier...
I have a Cobra 29 WX NW BT and i can not receive any transmisions unless the other CB user is right beside me. If they move more then a car lenght away i can see the signal come in but no voice. Also my PA...
You have a bad microphone. There is most likely a broken wire in the microphone jack.
Without a microphone the radio will not go into receive mode, at all. Same thing happens when there is a disconnected wire in the mic cord. Because the radio you have, has Talkback in it, you can always hear a little audio coming through, but not a lot.
Try a new mic or one you know is good.
Jun 11, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Got a knock now it wont work
hopefully the sensor in the mic is not damaged. if it is a new mic will be needed. I would sat that you may have broken a solder connection inside the unit and you will have to take it apart to see where the problem is. hope this helps.
May 08, 2010 | Peavey PVM 22 Microphone
How can I connect my P.A. system to pur phone system? cheaply easy Phone is NEAX PBX P.A. system is basic pre-amp output (analog)
This is very tricky unless your phone system has an analog audio line input provision. It's almost impossible to introduce external audio ( from your P.A. system ) into the phone system when a phone is on hold unless the PBX system has an external audio line input. If it does, all you need is a standard 600 ohm to 600 ohm audio transformer where you connect your P.A. systems preamp signal out to one side of the transformer and the other side of the transformer to your PBX systems external audio ON-HOLD line input.
Aug 31, 2009 | Audio Players & Recorders
My AKG Perception 200 Cut the signal suddenly
Sounds like a loose connection. Try duct taping the microphone cable in place where it enters the microphone.
Jul 27, 2009 | AKG Perception 200 Microphone
Doesn't pick-up sound
First I'd check the cable and make sure it's alright. Try another cable you know is good. If it still has low output unfortunately, it's probably the capsule.If the mic is new I'd send it in for warranty repair if not contact samson @ their website for repair info.
Apr 08, 2009 | Samson R21S Microphone
Peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Sounds like the basket has gone on the driver not sure if they are replaceable or if you will have to replace the entire driver, had the same problem on my impulse 1015, cost about £100 from a peavey dealer.
Dec 04, 2008 | Peavey PVM 22 Microphone
Peavey PVM 22 Microphone Logo
90 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
