Question about Breville Die Cast 800ESXL Espresso Machine
Breville espresso machine 800 ES
Steam wand leaking badly gaskets damaged
replacement gaskets in sydney south?
  • Tony Shaw May 31, 2008
    Steam is leaking all around the top of the steam wand, and hot water is dripping down. The join seems tight, and the washer seems ok, but I can't find any other adjustment to make or nut to tighten to fix this. Milk will not get to the correct consistency with so much leaking steam and hot water.
I have the same problem. It appears to be caused by a worn steam wand gasket that's inside the steam wand assembly which can be unscrewed from the Breville machine. This was confirmed by the folks at Breville. They referred me to www.thegourmetdepotco.com. That website does not sell the steam wand gasket separately. They sell "Frother Assembly MOdel #800ESXL-250" for $14.95. With tax ($1.42) and shipping via USPS ($5.65), the total is $22.02. A very high price for the failure of a simple plastic washer, but it beats buying a new machine!
Greg
Posted on Jun 16, 2009
  • Geva Perry Aug 27, 2010
    See below. You can now order the gasket separately from the Breville web sitehttp://www.brevilleusa.com/steam-ring-si...
Thanks gkmyer77, I now can order gasket separately via www.thegourmetdepotco.com, price USD 7.95 each
Posted on Feb 26, 2010
You can make a nylon ball seal and a rubber gasket. works well.
Posted on Feb 12, 2010
This gasket is now sold separately on the Breville site. Costs $8.00 + $7.00 shipping. http://www.brevilleusa.com/steam-ring-silicone-800esxl.html
Posted on Aug 27, 2010
    Genius:
  • 1,554 Answers
Http://www.breville.com.au/
Posted on Apr 02, 2008
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: My breville espresso machine is leaking at the top
The o-ring /gasket in there might be worn out.
Posted on Oct 07, 2009
EwingElect
  • 276 Answers
SOURCE: I need a replacement boiler gasket
If you're desperate and can find no help where you are, the Australian model has the same gasket. I should be able to help you out.
Posted on May 19, 2010
SOURCE: How to replace the swivel
Click on the link below to view the Breville 800ES expresso machine owners manual. Inside this manual it will show you how to replace the swivel steam wand:
http://www.breville.com.au/ssl/cms/files_cms/800ES%20Book.pdf
Posted on Dec 15, 2010
Ascaso Dream
If your steam wand is leaking then you may need to replace steam wand o rings. These can be found at Ascaso gasket kit Dream Arc Basic . Available in a kit with easy to follow instructions.
Try Dream Arc Basic Ellipse 150 Products
Feb 16, 2014 | Ascaso Dream Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
My breville cafe roma wand is not steaming it is just making air bubbles
Have you tried cleaning out the machine? My steam wand started just spraying out a steady stream of water but was not heating up. I used the cleaning solution CLR (8 parts water, 1 part CLR) and let it run through the steam wand for awhile. At first it just kept streaming out then all of a sudden it stopped. I still kept it on just to see what would happen. After about 10 seconds all of a sudden the steam wand shot out whatever had clogged it and it works perfectly again! I had only used the machine about 10 times before this happened. I had not been cleaning it well after each use back then. Now I definitely do.
Sep 13, 2010 | Breville ESP8XL Espresso Machine
Low pressure on milk frother on breville coffee machine
First,I'm NOT a Breville tech, but this is a very common problem with steam boilers. Your valve seal(s) are worn and needs replacement. Any leaking water or steaming from various places other than the steam tip is causing your tank to lose pressure. The heater needs to stay on longer just to keep everything up to pressure and properly heated. You probably noticed that your shots may not have the creme or very thin and watery. Milk steaming takes a long time or not enough steam to complete a froth, especially on a Latte. Your machine needs servicing. Contact your vendor or MFR for service.
** loose steam wands will fall off and be re-assembled without the ball seal or washer. Look around the machine for a round disk made of hard rubber or nylon plastic. Take apart the wand and reassemble with the washer or get a new washer and tighten,.
** other places were you can loose steam pressure is the Anti-siphon valve, Safety valve, and various pipe fittings to the steam boiler. Look for steaming plumes from unexpected areas of the machine.
** Scale that has built up to the point of causing valve problems are usually too much for DE-scaling to work properly. Usually done as a preventive maintenance rather an alternate to repair. Like a blood clot, if you remove it while still in an active system. Where does this clog end up? This debris needs to be physically removed from the pipes, valves, and/or tank. Heavy scaling is a sign of an old machine that will need a lot of servicing to bring it up to MFR specifications.
** Final; The steam wand(s) are the most used (and abused) parts of the machine. Constant cleaning is a required task that needs very diligent baristas to keep it fully functional. I've found that best operators use the following method to keep the steam wand in top condition; Remove milk froth pitcher completely from wand, Send a short blast of steam to clear milk residue from tip. Take a damp towel to grab wand an pull downward to wipe off any remaining milk residue. Leave the wand in a pitcher of cool water to soak during long break periods to help break up any dried milk. Let soak over nite when not in use. Have your operators notify you of any 'loosey-goosey" wands. Tighten them properly but make sure all the parts and washers are there. Check your manual or just ask your technician to show you the next time.
*Have a safe New year! Aloha! ukeboy57
Dec 24, 2017 | Breville Coffee Makers & Espresso Machines
No Pressure when extracting coffe
it's quite simple, Quite Simple: manual says packing grounds too tightly/ too fine a grind causes this problem; does your steam wand put out adequate steam? if so, don't pack so tight. of course, the manual is full of lies, so chalk it up to poor workmanship/quality control at factory/bad design/bad business practices a'la lower end breville machine. take yer pick.
Nov 05, 2008 | Breville ESP8XL Espresso Machine
Chrome on steam wand wearing off
Posted by compliance12@embarqmail.com
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in Breville.com but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at compliance12@embarqmail.com
Thanks
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
Steam wand, little water coming out, but no steam?
If you look at the end on the steam pipe you will see a nipple, loosen this and make sure it is clean.
Jul 25, 2008 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
2,145 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Steve
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
