Left Vertical Lines Misaligned, Ghost Shadow - SONY PROJ TV KP-43T75
Note: This is upper left-hand corner of the picture.
Observation: The left hand side has double lines for red and green and blue ghost (shadow) in the middle of the grid.
We have tried Service Menu to set the Skew/CENT option for RED, BLUE and GREEN. The problem we have is that the 3/4 of the screen is perfectly aligned and good. Only left 1/4 is the way shown above in the picture.
When we tried to align the red, green and blue for left hand of the screen they go out of the alignment in the rest of the right hand.
1. What seems to be the problem?
2. Is it possible to fix this problem w/ Service Menu or do we need to replace a part?
3. Are there service menu option to correct portion of the screen?
Thank you in advance for the help.
NH
  • 2 more comments
  • Anonymous Apr 09, 2008
    I have a KF60 XBR800 and I also have the same or similar problem. Mine is a faint blueish green ghosting which is uniform across the entire screen. The shift is about 3/4 of an inch.
  • fredley Oct 25, 2008
    I have a Sony KP-43T75 and the issue appears the same. The alignment is fine on the right side of the screen, but the further left you go, the worse it gets. I have tried using the flash focus option, but it does not resolve. I have not been able to find any way to manually adjust.
    Can anyone help?
    Please?!?
  • Anonymous Nov 20, 2008
    same puple lines
  • JEFFIAH Dec 08, 2008
    ALL OF SCREEN IS OFF VERTICALLY BY AN INCH. ALL LETTERS AND NUMBERS HAVE SHADOWS TO THE LEFT AND HD QUALITY IS SHOT. I CANT BELIEVE YOU CANT MANUALLY ADJUST CONVERGENCE LIKE ON THE OLDER BIG SCREEN PROJECTION TVS BY SONY
5 Suggested Answers
  • 1030 Answers
SOURCE: tri coloured ghosting
maybe...it might need service mode aligning be a tech
Posted on Jan 03, 2008
  • 185 Answers
SOURCE: red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Posted on Dec 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2009
SOURCE: Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Posted on Jun 13, 2009
I pressed a button by mistake and my Sony tv has no picture. Now has small box left hand upper corner with A and lines like wifi icon
Try the RETURN button on the remote to get back to viewing.
Get the manual at Sony KDL 40S2010 Manuals See page 11 for remote control keys and page 38 for further trouble shooting if necessary
Jun 03, 2016 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony KP-46WT500 has a yellow arc of color on the upper left side that never goes away even with plug in devices like Wii. It started about 6 months ago and has gotten worse over time. What can I do?...
Very common problems,through out the DLP tv life cycles could happen again again until end of the tv life itself.The tv have a problems known as a convergence picture problems,it is dead.Tv have any colors lines like R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes?Than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The Shop will cost u like $300-350 for parts and labors.
Aug 03, 2011 | Sony KP-46WT500 46" Rear Projection...
Video input channel stays on screen in upper left hand corner of my sony 57in hdtv rear projection
WITH AN ORIGINAL SONY REMOTE HIT THE DISPLAY BUTTON TO REMOVE THE INPUT ON SCREEN DISPLAY---IF YOU leave it on long enough it will burn that image into one or more of the 3 picture Tubes.
ALMOST ANY SONY TV REMOTE WILL WORK FOR THIS FUNCTION.
sd tech
Oct 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-43T75 color repair
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
Jun 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Wavy Lines
some type of electrical feedback try upgrading your cables or tightening the ones you have. what might work best is a line conditioner i filters out any feedback you may be getting and cleans your power supply they cost from 50.00 and up best buy or circiut city both carry them or online as well
Jul 17, 2008 | Sony KP-53HS10 TV
SONY KP-43T75 HAS ISSUES
well sound like convergence for one and maybe another problem. First look at customer settings and look at convergence and try to realign. Then you can in Standby mode(Power Off) Press Display 5 Vol+ TV power on Remote. Fast. Now do you know what you want to get to? Because changing things here could cause serious problems with your set.
Sep 21, 2007 | Samsung TXM3281HF 32" TV
Televison & Video Logo
529 people viewed this question
Top Televison & Video Experts
