I am trying to install my new PSC 1510 printer from HP, but every time I try to install the driver, halfway it abords, giving a message that the system can not find a file: D:\Setup\hpzprl01.exe -m preload product drivers (and then a lot of countrycodes) I've attached the detailed errorlog. Please help me!!!! I have tried to find info on the internet, and on the HP sites, there is mentioned that I should try changing the systemlanguage/area code, but also does not help. Has anyone ideas how to proceed??? cannot install printer. just stops before completing installation. pc does not recognize hardware.
Download the newer drivers & software from
http://h10025.www1.hp.com/ewfrf/wc/
softwareCategory?lc=en&cc=us&dlc=en&
product=428800&lang=en&
select your operating system and then download " HP Full/Express software and drivers: No Network Support"
this should fix your problem.
Hi, if you still have fault, while you installing driver, i believe you get this fault at a half way of installing, if so, when this fault appears, click on the brows button and show the location to pick the installation drive from your system folder itself. i mean, please try to select you windown/system folder (syster32) or select the folder where your files are extracting...
while you trying some of the area, you can see the missing file. just select the same and go ahead....
but while on go it may ask for missing other files, try to show the driver installation CD drive at this time...
hope it will work for you.
HP Deskjet 1510 Driver Download
I cant install printer driver
Have a nice day and do not forget to rate please...!
I will try it to but.. I download the first driver the basic http://h10025.www1.hp.com/ewfrf/wc/softw...
my problem is little different.. when I install and I'm installing to the 3rd step I have an error
" C:\Temp\HP_Webrelease\setup\hpzprl01.exe - m preloadproductdrivers ...
hp photosmart 8250
hp photosmart 8250
i have the same problem with hpzprl.exe
i got error ink system failure
