Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Have an ADATA PD16 - 16 GB Flash Drive
The flash drive is write protected and cannot be accessed, every message says a portion of the drive has been write protected. The problem is that I have never set the a protection password for any of it, all I've ever done is formated it and transferred files with it. Tried to reformat but am locked out. It does not have an external switch, I have examined it under a very large well lit magnifying glass. I have tried the software that came with it but nothing works. Can you help. All files are replaceable but I would like to use the usb drive again, only had a month. I even wrote to A DATA tech support , no answer.
  • drdvd Feb 24, 2008
    16 giga bites in a thumb drive
  • junior franco May 11, 2010
    what size is this device?
Posted on Mar 28, 2008
  • 50 Answers
Formatting this device makes it so that it is impossible to render the driver for it. You need a new flash drive. The reason for this is that the space on the drive doesn't recognize itself to be writeable. To empty files you must delete them, not format the entire drive.
Posted on Feb 24, 2008
Flash drive not detected, not accessible
You'll need to try a file recovery program to attempt file recovery.... Bad Copy Pro 4.10.125 works great for me. Then you will need to reformat the card to fat32 file system. That software is usually available from the manufacturer. It sounds like you have a defective card but you can try the above to see what the results are.
Mar 23, 2014 | Electronics - Others
How to write password my 16 gb pendrive flash drive
To password protect a USB flash drive the best way is to go for the encryption option so if its lost you are still protected has many are still accessible if lost.
http://www.truecrypt.org has the free software and instructions but you will have to copy your files to a pc first and then copy back when the drive is protected
Apr 05, 2012 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
Flash drive write protected
go to my computer ,then double click on the flash drive icon and then it will ask you to format your flash drive . it will take a while depending on your flash drive for eg if you are using 16 GB it will take long ,but if you have 8 GB flash drive it won't take long .hope it works for you guys .
Jan 29, 2012 | NexxTech Computers & Internet
The Disk is write protected
  • Check for a write-protection switch. This switch, when engaged, will lock the contents of the flash drive and is a very common security feature. It is generally located on the side of the flash drive, and has an "enabled" or "on" position, and an "off" position. Slide this into the "off" position.
  • Override password security. If your flash drive has password security, but you have forgotten the code, you can try to override the security feature by going to the Start menu and selecting "Run." A dialogue box will pop up, into which you should type in the path to the file on the USB drive you want to access. Note: This only works on USB drives with very simple security. If the security is complex, this will not wor
  • 3Format the flash drive. If nothing else works, you can always format your USB flash drive, which will set all your write protections back to default. From there, you can customize them however you want, but all your data will be lost. To format the flash drive, go to the My Computer, right-click your drive and select "Format." A status bar will pop up. Once the status bar disappears, you can change the write-protection settings on your flash drive without incident.
  • Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    Usb write protect
    i have 8gb flash drive but i have problem i can't open it.error come is flash drive write protected.
    Oct 22, 2010 | A-Data Technology Adata USB C802 8GB BLK...
    My Memorex USB flash drive is write protected
    t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
    Note: your files will be erased if you format your flash drive.
    If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
    May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
    In trying to save a file to my flash drive, I get
    I did not fix the problem but was able to transfer the files on it to another flash drive.
    Dec 05, 2009 | iLO (2 GB) MP3 Player
    I had problem with imation lock
    how format flash imation 8 gb write protected
    Mar 25, 2009 | Electronics - Others
    Just got a sandisk cruzer 8 GB (with U3). I want to copy files from hard drive to flash drive. Error says :cannot create or replace 40: access is denied". But i can copy the same files from hard drive to...
    Hi there
    Have a look at the side of the flash drive for the copy protect switch and turn it off. Job done!!!!!!
    Good luck and thanks for using Fixya
    Jan 13, 2009 | Cameras
    SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
    204 people viewed this question
    Top SanDisk Computers & Internet Experts
    Arora Singh
    Arora Singh
    Sandy Moore
    Sandy Moore
    Alun Cox
    Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
