Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Loud Noise When I start the vacuum, there is a loud noise that sounds kind of like a table saw. It may be because I placed the bag on wrong and the dust may have clogged something. Do you have any suggestions?
Loud noise that doesn't stop. changed bag, cleaned roller, etc.
Posted on Aug 16, 2008
  • 126 Answers
This sounds like something is caught in the brush roller. It is not uncommon for something like a pin, or nail or something of that nature to get caught in the roller chamber and when the roller spins, it will rub on the roller producing that sound. Sort of like putting a playing card in the spokes of your bike when you were a kid. Take the bottom plate off and remove the roller. Inspect the area around the roller for any foreign objects. While your there, check the belt for wear and tension and also check the roller bearings for any material that would interfere with it's smooth rotation. You should also check the hose intake for blockage.
Posted on Feb 24, 2008
Have a bagged Biss ll Powerforce vacuum that has started making a loud rattling noise under the base of the motor compartment. Noise is louder when using the hose. Suggestions? Thank you!
Something broke or got sucked in and is trapped in there. Put it up on a table and take the bottom apart, it's time to clean the roller anyway :)
Nov 02, 2016 | Vacuums
Loud whistling noise it is just going on five years old when I pull it backward a loud noise emmits
If you whistling is only happening when pulling back on the machine, the problem is with the connection between the bag housing and the swivel neck. There is a rubber gasket between the two, located on the bottom of the bag housing. Check to see if this seal is in place. If it is there and in good shape, check for excessive wear on either the swivel neck or bag housing. Windsor Sensor Vacuum Seal 5163 86144910 allstar javelin
Apr 02, 2014 | Windsor Vacuums
Loud high pitched noise from Electrolux Vitesse petlover 1700w
We had a vacuum cleaner that did that and it was the signal to say the bag was full. So to test this remove the bag and see if problem goes. If it does- replace the bag.
Dec 28, 2011 | Vacuums
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
I was cleaning my carpet and my Kirby sweeper started making a loud noise. What is wrong with it:
hi it could be that the bearings on the motor are starting to go how old is the vacuum
Feb 16, 2011 | Kirby G5 Bagged Upright Vacuum
Loud noise while running
Vacuums typically make a loud noise when running. Can you describe the noise or why you think it is unusual?
Feb 10, 2011 | Eureka Bravo II Bagged Upright Vacuum
Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Apr 13, 2009 | Vacuums
Hi folks, my beam vacuum makes a very loud roaring noise quite often. the problem started when i was vacuuming up a quantity of vermiculite from my chimney. i think i overloaded the vacuum i think and...
If the filter bag is bad and didn't trap all of the dust, then it got into your motor, so you may have a problem with your motor now.
Apr 20, 2008 | Vacuums
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
294 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
