Question about Mitsubishi DiamondPoint V50LCD (Black) Monitor
Mitsubishi diamond point v50 lcd
When i turn the monitor on the screen goes green red and then black the power light stays orange instead of green i cant access the menu options or anything im not sure if this is the right power cord for it i dont know if that would cause it or not.
Thank You
Christopher Moffat
ctmoffat@hotmail.com
  • ctmoffat Feb 24, 2008
    ok figured it out it was the power cord got a new one and its working fine
ButtFuzz
  • 463 Answers
SOURCE: mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Posted on Mar 02, 2009
SOURCE: I have a Mitsubishi WDC657 with a bulb that blew
I have the same tv (mitsubishi WD-C657 from Costco) with the same problem. (When turned off the lamp light is red, and when powered on the screen stays black but I hear white noise) Before I order a new lamp I want to make sure that this is the correct fix. If anyone knows the correct fix please email it to me at twistedfate775@yahoo.com =)
Posted on Sep 21, 2009
Slinteriors
  • 8617 Answers
SOURCE: i have a mitsubishi tv model # wd52725, the timer
Thats caused by failed capacitors on the DM board. You can get the V26 DM repair kit at www.tvrepairworld.com which should fix that issue. The kit contains the capcitors and the CD with detailed repair instructions.
Posted on Jan 03, 2010
  • 21 Answers
SOURCE: Mitsubishi Diamond TV power went out TV wont turn back on.
the regular problem is the convergence kit,
Posted on Jan 20, 2010
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
Screen keeps flashing green-blue-red
The manual for the monitor can be found here (
Mitsubishi DiamondPoint V50LCD User Manual ) The specific Red Green Blue cycle isn't noted.
  1. I'd start with toggling on the on screen set-up display. if that comes up and is legible, then you know that the screen is working.
  2. What is your video set up to push to the V50? If it's not a supported resolution, the display may respond this way. try downgrading it something like VGA (640x480) and see if that works. (The max resolution shown in the manual is 1024 x 768, so don't go higher than that. It's also 24 bit color (8 bits each for R,G,B, so don't try to push 32 bit color to it)>
  3. Set the output to your primary monitor to 1024 x 768, thousands of colors. Make sure the monitor sees it OK. Now you know the first monitor and cable are OK. Now switch the cable to the V50 monitor. Do you get a signal now? Then the display works. Try putting your primary display on the second cable. Does it pick up anything now? No. Maybe a bad cable.
  4. You can try swapping the cable going to the V50 to go from your primary monitor output port on the computer to your primary monitor. if the primary monitor works OK, then the cable is good.
  5. Depending on the computer system you're on, make sure that you at least have a generic monitor driver installed for the V50 output. Ideally, get the driver for the monitor You can get the driver here (
Mitsubishi Monitor drivers ) amongst other places.
Nov 11, 2015 | Mitsubishi 15" Diamondpoint V50lcd-Bk Lcd...
Power light comes on green for a second then goes orange, then red with no test screen just stays blank
Check the CPU, If ok then check the CRT neck pcb supply and pcb area..may be dry solder..
Jun 25, 2009 | Sony PremierPro SDM-P232W/B (Black,...
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Computer monitor problem
ok the problem is not the monitor it is either the cable checke each end for bent pins inside or the computer you are trying to use
Jan 13, 2018 | Computers & Internet
Dell Monitor won't stay on
When it goes black, does the power buton stay green or is it orange? If it's orange, the power supply/inverter is your main culprit. If the power button stays green, it sounds like the backlight for the display is bad. Either way, unless you have parts for the same monitor laying around to swap out, you're due for a new monitor. The good news- with the economy in the tank, you can search online and find some reputable vendors selling nicely sized screens for less than $100! Heck, I've even seen a 22" for $129 (once but it was there).
Sep 23, 2008 | Dell E177FP LCD Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Screen went dark
can you confirm make and model number please.
Dec 10, 2007 | Mitsubishi WS-55807 TV
Computers & Internet Logo
217 people viewed this question
Top Mitsubishi Computers & Internet Experts
Alun Cox
john h
richie46
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
