Question about Sharp LC-46D64U 46 in. LCD HDTV
Sharp Aquos TV
Whenever there is music or applause on the program a display appears saying Cable, Analog (the channel number) audio and mono. How do I stop this from appearing on the screen.
  • Anonymous Jan 16, 2009
    The channel display (with Audio: Mono or Stereo) will appear often and randomly on the screen, especially during commercials. It's a brand new TV... sorry to hear it can't be fixed, I'll get my money back :(
    Thanks for the info, very useful!
  • idupuisi Jan 17, 2009
    (I am the guest from the previous post)
    Wow... when I called Sharp about my problem, they told me this was "normal", that it happened because of signals my cable company sent to my TV... What do you say to that?
    Problem Solver:
  • 3 Answers
I just hung up from calling Sharp's customer service: I have the same problem and there is nothing to do about this, the television merely reflects the signal your cable distributor (I suppose that, like me, you have cable) is sending to your TV. If the signal fluctuates, the TV will show it, no maintenance can make it stop, it is normal behaviour for the TV.
According to Sharp, a way to solve this is to get a better, more stable signal from your cable distributor or switch to satellite; getting HD cable would apparently greatly diminish the frequency of this display.
Posted on Feb 19, 2009
The tv wont turn on ... the gren power display keeps blinking and won't turn on...
What can I do? Thank-You! KarL
Posted on Mar 23, 2008
  • 53 Answers
How many times is the POWER LED blinking? (Don't worry about the OPC LED).
1x = Bad inverters/lamps
2x = Bad Power Supply
3x = Bad Main Board
Either way, there isn't anything you can do to fix this, you need to contact Sharp to have your TV serviced.
Posted on Mar 25, 2008
32 " Sharp AQUOS LCD
Go into your Menu under audio, and look for SAP, then turn it off. ( Second Audio Program )
Oct 05, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Apr 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Jan 25, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Open Questions:
See all Sharp LC-46D64U 46 in. LCD HDTV Questions
Sharp LC-46D64U 46 in. LCD HDTV Logo
400 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
