Question about Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Dishwasher Hotpoint dishwasher Model # HDA3400G02BB... SN AG82532Y Problem is the dial will turn but the washer is stuck in wash only no matter where you put the dial it still washes only..
  • 105 Answers
If you say it washes it may be confused with the drain pump running all the time
if this the case the machine may have a flood switch in base of machine this means that the machine has flooded or has a leak so you need to pull machine out take outsied and check for leaks
Posted on Feb 24, 2008
My Hot Point Dishwasher is leaking water. It was
Hi
Check for any kind of leaks around lower spray arm or soap door. Replace the arm if any cracks are found. Also make sure that door latches firmly, and the gasket is not cut.
The leak can also happen due to a broken fill valve. To check, take off the access panel from the front of the dishwasher so you can reach the fill valve attached to the metal bracket. Use a multimeter to check the continuity across the two black terminals at the top of the fill valve. If it reads 120 V, replace the fill valve. Make sure the thin filter screen between the bracket and fill valve is not blocked by debris.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | Hotpoint 24 in. HDA3400G Built-in...
I have a hot point model hda3400g02bb it doesnt seem to drain is there a filter thats clogged or something like that or a pump?
Not your pump. At the back of the dishwasher you will see what looks like a screen. 4 screws hold this in. remove the screws and you will see right in the center a plunger assembly. Replace this because the small rubber cone is eaten away. Cost less than 20.00.
Jan 27, 2010 | Hotpoint 24 in. HDA3400G Built-in...
I have a hotpoint HDA3400G02BB leaking from bottom front. I'm guessing door gasket?
that is a good guess, but you should also check the overflow float inside the machine. if it is stuck down, then it may be overfilling. the gasket is supposed to stop splashing water. it is not an under water seal. if the float moves freely, its gotta be the gasket. good luck
Oct 27, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Circuit board
It sound like a malfunction circuit board issue that shouldd be replaced.
Jun 20, 2006 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint 24 in. HDA2000Z Built-in Dishwasher Logo
157 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
