Hi there, your phone memory is full that's why these message. How to solve? OK . Follow these carefully.
1. transfer all your Contact phone memory to Memory
card.
2 . Click Message then press Option. Select Setting
& then Others. Now open the Other & select the
Memory in use option. When you click there you
find two option. # Phone memory # Memory Card.
Just select Memory card and save the settings.
After that confirm your self that, all the contact are transfer in Memory card. In future when you received a message or add a new Contact that will save in your Memory card & your phone memory will have a free space. Even when you install games /song/photos/movies etc Select the Memory card always.
Thanks & waiting for your feedback.
SOURCE: my phone says memory full. delete some data.
press the following code and your problem will be solved
*#7370#
it will clean all your phone memory but not the original software
SOURCE: memory full, delete some data
If you Memory card is also full. Backup all your data to your PC and delete some data in your mobile.
Hope This Helps!!! Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
SOURCE: HOW TO REFORMAT PHONE MEMORY OF NOKIA N73
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
Hope I make it clear and does makes sense.
Thanks..
Testimonial: "it does not work. My phone asks for a lock code. 12345 is not the default key. It is locked. "
