Question about Kitchen Appliances - Others
Meyer electric kettle electric cord
Hi, I have the Meyer 496 1.5 kW 120 VAC 1.7 ltr. electric kettle. The power cord broke. where can I get a new plug?
robotek
  • 1512 Answers
SOURCE: MC1 Switched Power Supply
Hi Hansjo. You may find that if one capacitor has failed, then there may be more. If you see any signs of bulging, leaking, or pushing the bottom out of any caps, then It is a good idea to just change them all. For the small expense, it is worthwhile knowing that your power supply has fresh caps. Try the amp and then see how it goes. If you still have problems, get back to me here and we can talk about it more.
regards
Graeme
Posted on Feb 29, 2008
SOURCE: Canon Powershot SD1000 Lens Will Not Retract
This is a huge recurring problem with Canon cameras. check out this website-give it a minute to load. You will see literally thousands of people with the same experience.
http://e18.bitnet.cx/comments.php?full=1
Posted on Aug 22, 2008
t_vinson57
  • 58 Answers
SOURCE: Power transformer broke
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: Tefal electric kettle (vitesse) works sometimes.
hi i hope i can help you with this? you dont have a short in the chord as this would be a fire danger. may i please ask if you have a multimeter. check the fuse if ok check for a breakage in the mains cable ie conniunity if ok open up and check to make sure there is power going in? if ok? please check the switch if power is going into the switch put the probes to the other side of the switch if no reading the problem is likely to be the switch. i hope this will help you?
Posted on May 07, 2009
  • 512 Answers
SOURCE: Melted base of electric kettle FB 1735
Quit buying them, they are pieces of junk if the base keeps melting, that or you are using it beyond it's rated hourly heat time.
Posted on Sep 02, 2009
Leaf curl on my Meyer lemon
Generally Meyer Lemon Trees need water every one to two weeks. ... If the leaves are drooping like they're too heavy for the branches, and turning dark brown or black the tree is getting too much water. If the leaves are crispy and dry or curl upwards this is a sign of under watering.
Meyer Lemon Trees: 7 Secrets for Loads of Fruit ' Fast-growing-Trees ...
Citrus Leaves Are Curling - What Causes Citrus Leaf Curl
https://www.gardeningknowhow.com/edible/fruits/citrus/curling-citrus-leaves.htm
Dec 29, 2015 - As far as fruit trees go, citrus tend to be the low-fuss member of the team; but when curling citrus leaves appear, you'll need to intervene. This article will help that. Click here for more info. ‎Citrus Fruit Brown Rot · ‎What Is Horticultural Soap · ‎What Are Psyllids: Tips On ...
Leaf Curl - Four Winds Citrus Problem Solver - Four Winds Growers
https://www.fourwindsgrowers.com/solving-common-problems/leaf-curl.html If the leaves on your dwarf citrus are curling, there are three common possibilities: Some insect pests will cause some leaf curl. In spring, aphids might do this on soft new leaves. ... Overwatering can cause leaves to curl or cup INWARD.
Why Are the Leaves on My Meyer Lemon Tree Curling? ' Hunker
https://www.hunker.com > ... > Garden & Lawn > Pests, Weeds & Problems May 6, 2010 - Pests. A number of insects can cause leaf curl in Meyer lemons. The most common and likely is the everyday whitefly, but aphids, citrus leaf miners, and mites are also common culprits. Insects are a larger challenge to manage than over-watering.
Meyer lemon Leaf curl Google Search
Jan 29, 2018 | Garden
Meyers plow blade doesn't go right
I had the same problem with my 7'6" with an e47 power unit the plow would angle left not up or right. I had to replace Meyer (B) Solenoid Valve Assembly, Red Wire . If you go to the meyers products website they have a troubleshooting chart that is extremely helpful . I found parts are alot cheaper through amazon.
Feb 03, 2014 | Meyer 6 8" Drive Pro Complete Truck Snow...
Need a temperature control unit pa 8300,for a Meyer Work
Try Meyer Customer Relations
http://www.meyer.com/contact_us.html
In 1998 I lost the cord for my wok (don't know the wok model as I do not have the wok now). Meyer sent me a replacement. The TEL number I called was 800 326 3933.
Jul 18, 2011 | Meyer 48986 Electric Wok
I need a replacement cord for an electric steamer/fry pan. The model number on the back of the cord is PA8300. Can you help??
http://www.meyer.com/kbReplacementParts.html
If you go to potsandpans.com and type cord in the search....
SKU # RP025
I dunno if this will work for you. It priced at $8.99.
Circulon Electrics
Fits model #48785, 45681 and 45881
Fits only Circulon Electric: Wok, Griddle and 12'' Saute
You may contact them by telephone Monday through Friday, 7am to 5pm PST (Pacific Standard Time) excluding holidays.
(800) 450-0156. This is potsandpans.com
Meyer 800 numbers => http://www.meyer.com/contact_us.html
Dec 26, 2008 | Kitchen Ranges
Kitchen Appliances - Others Logo
52 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
