Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Dish washer frigerdaire, some dishes do not come clean
Cups have a grit on them not clean pkates like they were left for days without washing , even though basicaly clean when washed, silverware is the only thing that comes clean
  • lovnlin Feb 26, 2008
    blw out the water hose and cleaned atns works good now
    President:
  • Frigidaire Master
  • 2,651 Answers
Ck water level, a few min into wash cycle open door . make sure your water level is just below heater coil
Posted on Feb 24, 2008
We just purchase home weeks ago.I opened the bosce dish washer found it had a musty order.The following day i ran a dish washer agent,which didn't work.clean the washers filter noticed green algee.
Put two cups of bleach in it and run it on a long and hot wash. The best way to stop the odor is to use it regularly and leave the door open for 15 minutes after you use it so it can dry out a bit. There will always be some water in the bottom in the pump.
Sep 23, 2017 | Cars & Trucks
Water in the bottom dw smells.It's not from wet dishes dripping.It just appears every few days.Would my disposal have something to do with it?I don't know how to take it apart to find out.
try washing without dishes with a cup of vinegar or get a product at the store call dish washer cleaner that you use it in and empty dish washer to clean and remove smell.
also could be clogged strainer in the bottom of DW then need to be cleaned out!
Sep 04, 2016 | Magic Chef Dishwashers
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
I use siemens dishwasherand recently noticed some grit like substance left on my dishes etc after every wash
There should be a screen under the spray bar. Make sure that is clean. So "grit" is not recirculated in the wash cycle. Is "grit" showing up in your house water elsewhere? Check with clear water glass. Also consider testing with a competitive wash compound to see if there is any difference. A sample or from your friends.
Apr 14, 2015 | Siemens Dishwashers
Danby counter top dishwasher leaves residue on dishes
Make sure It's not a soap issue by running a load or three without any detergent.
Jan 11, 2015 | Danby Dishwashers
How to remove black mould from rubber door seal
the best thing to do is replace the rubber boot.
Mar 19, 2011 | Washing Machines
Lots of mold around rubber gasket; unable to clean off; odor from mold; water in detergent trays; maybe some water leaking from washer; washer bought in 2008
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
Feb 09, 2011 | Frigidaire GLTF2940ES Front Load Washer
There is a smell like rotten eggs in the washer.
If you have used a non HE detergent in your washer this smell will occur often. Even using HE detergents over a period of 1 year since new they can get this odor. There are products on the market like Affresh: http://www.affresh.com/#/home or Tide washing machine cleaner: http://www.tide.com/en-US/product/tide-washing-machine-cleaner.jspx?ms=true (select info)
What you can do is use a full cup of bleach and 1/4 cup powdered Dawn dish washing soap in your washer with some non greasy rags. Dump it straight into the tub (not via the dispenser) and run a HOT wash. You can also add a squeeze of lemon at the same time or lemon concentrate. If it has been a long time since a machine cleaning cycle you may have to do this 2 times. It is recommended you perform a machine cleaning cycle at least every 90 days.
Any feedback via a response here of your success or failure to get rid of the bad smell would be greatly appreciated.
Thanks for using FixYa.
Kelly
Jun 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Despenser cup - Kenmore dish washer
hi
the dispenser will always open when the washer goes through it's regular cycle. I would recommend to only use powdered soap, that is what the washer was designed to work best with.
Mar 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
220 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
