Question about Cameras
How to?..... how to i take the images from my internal memory of my camera and put them on my memory stick duo to upload them to my computer? by the way my camera is the sony cyber-shot DSC-H3 which isnt under the products list
  • Triniboy121 Feb 24, 2008
    help me please
  • 25 Answers
You should be able to transfer the images directly to your computer without transfering them to you memory stick duo. Have you tried connecting the camera to your computer and retrieving the images? If you would rather have the images on your camera on your memory stick duo, then remove the memory stick duo connect the camera to your computer, copy the images off of the camera, turn the camera off, put the memory stick duo back into the camera, plug the camera back in, then transfer the images that you just transfered from the cybershot to your computer back to the camera. They should copy directly to the memory stick duo.
Posted on Feb 24, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
How do I change from internal memory to external memory on my camera?
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->Memory Stick Tool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Thanks for using FixYa.
May 09, 2011 | Sony Cyber-shot W290 Digital Camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Transfer internal memory to memory stick. Olympus camera
Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
Jan 11, 2010 | Olympus FE-280 Digital Camera
How do you upload pictures on the internal memory?
If you normally upload your pictures by connecting via the USB port, remove the memory stick before connecting the camera to the computer. If you normally upload your pictures by putting the memory stick into a card reader, use the camera's memory stick tool to copy the pictures from internal memory to memory stick.
Nov 15, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My cybershot w120 keeps saying no space on internal memory when i have a new memory card in it which is empty. This happened with my last card so now i am thinkng its more a camera problem rather than the...
in your settings is it set to "shoot without card"? this could cause the camera to not use the memory card installed and rely on internal memory which is limited
Aug 26, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
2gb stick is the pits for me...
check your pc because your pc occur a risk of virus change your antivirus then format your sony pro duo 2gb.
ok
Jul 30, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Need to put Pictures from Camera onto Memory Card
Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
Feb 14, 2009 | Kodak EasyShare C330 Digital Camera
Unable to upload pictures from memory card to computer
Most laptops that have a memory card reader will only read these types of cards, without needing an adaptor: -SD card -MMC card -Sony Memory Stick or Memory Stick Pro cards -XD cards
However, you have a MS Pro Duo card, although it fits into the card reader slot, the card is a lot thinner than what's expected, so the laptop won't be able to read it.
You need to put the Pro Duo card into the stanard size MS Pro caard adaptor. See attached image.
Hope this helps.
Jan 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Cameras Logo
461 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
