OKI MICROLINE 521 Matrix Printer Logo
Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing does not conform to the spacing of the pages on A3 continuous stationery
mukhtar21 shaikh
Level 3:
President:
  • OKI Master 2,022 Answers
  • Posted on Feb 11, 2010
mukhtar21 shaikh
OKI Master
Level 3:
President:
Answers
2022
Questions
Helped
668870
Points
5817
Kindly set the page lenght and the font size and mode in printer setup by going in to printer menu by pressing the pause and menu button.
tip
Tips to Choose an A3 Printer
When it comes to printing, there is a wide range of printers available. Primary <b>A3 printers</b> to print pages that are double the normal <b>A4 page</b>. <b>A3 pages</b> is useful when you want to print a large amount of data or a poster in an organization. When you want to make a difference with your A3pages, you should have the right <b>printers A3</b>. While choosing your<b> A3 printer</b>, there are some things to keep track of how you choose.<br /> <br /> There are several types available in the market. You need to know what you want in your<b> A3 printer</b> that you will use. When you have a clear idea of how to choose a<b> printer A3</b> becomes really easy for you.<b> A3 printer</b> comes with many features such as <b>A3 printer scanner</b> added, direct printing from <b>USB flash drives</b>, using the <b>A3 printer</b> and a fax with <b>A4 printer </b>as a copier and even a Wi-Fi and <b>network interface</b>.<br /> <br /> With so many options available, you need to know how to choose an <b>A3 printer</b> to make a wise investment. Even though prices have been reduced, they can be very pricy. Instead of buying an <b>A3 printer</b> that has all the integrated features, you can choose only those needs that you need. This will save lots of money.<br /> <br /> <b>A3 printers</b> are easy to maintain, you must be prepared to do regular checks. If you do not want your<b> printer</b> needs servicing often, so please select the top sustainable. They require frequent maintenance or filling of cartridges, as they will last far beyond the normal flow of <b>printers</b>.<br /> <br /> How to choose the<b> printer</b> is a very important aspect, especially when there are so many options available. Each printer has its advantages. You may have the same characteristics of the second<b> A3 printer</b>, but it could fit right, if you want, within your budget and needs. In addition, you must decide whether it should be for commercial purposes or common house hold. It is <b>A3 printers</b> with different capabilities, such as the number of pages per minute, so in the light where you need a<b> printer</b>, you should opt for an<b> A3 printer</b> wisely and make best use of it<br />
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Printing on an HP 1220c Printer scanned photographs
Go to Start
Control Panel
Right click on Printers (on the left hand side of the screen)
Click on Run as Administrator
Click on Server Properties
Click on Continue
Click on Create a new form
Put in the sizes you want (which for you is A3 measurements)
You can do this to create whatever size page you want to print up to A3. All the best .. Tina
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
