Kirby Ultimate G Bagged Upright Vacuum Logo
Posted on Feb 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i put a belt on my kirby vaccum
Kirby
Anonymous
Level 2:
Sniper:
  • Expert 112 Answers
  • Posted on Feb 24, 2008
Anonymous
Expert
Level 2:
Sniper:
Answers
112
Questions
Helped
87404
Points
295
Here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps! :)
5 Related Answers
Anonymous
  • 438 Answers
  • Posted on Mar 20, 2010
SOURCE: how do i replace my belt on my kirby vaccum
Please see the following video we've shot on how to replace the belt on a Kirby Generation vacuum cleaner. This should explain to you step by step the procedure to replace the belt. If you need to purchase a belt, we can also help you with this.
Feel free to request a repair clarification if you have any questions I can answer.
If you found this repair helpful, please be sure to rate the repair by clicking the 4 Thumbs Up Icons in the top right hand corner of the repair. Thak you so much.
Chris Jones
GoVacuum
Anonymous
  • 126 Answers
  • Posted on Jan 13, 2008
SOURCE: kirby vaccum ultimate G
Lift the light bulb housing up and you will find a latch that will rotate to release the front agitator housing and remove it from the machine. On the bottom of that housing, there are two latches that secure the bottom plate that covers the roller. Remove the plate and the roller will come out. Be sure to notice that the roller has a magnet at one end that lines up with the indicator that shows you when the roller is turning - it's the little green light that glows while you are vacuuming. The roller needs to go back in the same way it came out. O.K. Take your new belt and position it around the middle of the roller and drop the roller back into place and replace the bottom plate. On the front of the housing, there is a big square "knob" and you can rotate that piece. If you look inside the hole on the other side of the agitator housing, you will see that there is an arm that moves with the square knob. The end of this arm will catch the belt and with a little effort, the knob will rotate and lift the belt into position for replacing the housing back on to the machine. once you have the housing back on the machine and secure, you rotate the square knob back around and the belt will sit down on the drive shaft. If you look at the top of the agitator housing just above where the knob is, you will see a red and a green arrow which indicate which way the knob turns to do the "remove" belt or "replace" belt. I hope this helps. Once you do it properly, it actually is quite easy.
Anonymous
  • 1673 Answers
  • Posted on Feb 21, 2008
SOURCE: how to install kirby vaccum belts
Take the noozle off of the vac. take out the brush roll and old belt, put the belt over the brush roll and re-instal in the noozle. Turn the big square knob on the front os far as you can, it will lock in that position, then put it back on the vac and lock it down, then turn the knob the other way to release the belt unto the belt pulley.
TJ
  • Posted on May 02, 2008
SOURCE: Kirby Vaccum
Rotate the square knob on the front of the attachment to the "Belt On" position (green marker). Insert your fingers in the attachment port (the round opening on the back where the "hook" is) and position the belt so it's centered and as high up as it will go (that's usually just below the center of the opening. THEN rotate the square knob on the front to the "Belt Off" position. You should feel the belt tighten up and the know harder to rotate.
TJ
Anonymous
  • 19 Answers
  • Posted on Jul 15, 2009
SOURCE: belt for heritage 2
remove power head turn knob on front counter clockwise look in hole on back of powerhead make sure belt is on the hook install powerhead back on motor turn knob clockwise
How to put on attachment hose
Here is a walkthrough on that with pictures:
Vacuuming Bare Floor with Kirby vacuum
You will need to take off the nozzle to attach the hose.
Install Kirby belt and nozzle
800-775-6586
GoodVac com
How to put a belt on silver addition kirby vaccum cleaner
The following site has videos for changing belt on the Kirby vacuums. It should apply to your. Much simpler and better than just a written reply.
http://www.kirby.com/portals/0/videos.html
Sep 23, 2010 • Vacuums
1helpful
How do i replace my belt on my kirby vaccum cleaner
Chris Jones
GoVacuum
Belt for heritage 2
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
1helpful
Kirby Vaccum
TJ
6helpful
How to install kirby vaccum belts
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
