Question about Car Audio & Video
Wirng up a bw10000 car alarm to a dj systems siren
Hi there Im trying to install a new siren on to my existing Black widdow 10000 car alarm.
I am having a few problens as my siren has a standard black and red wire system however my alarm has a Black, Red, Blue and Grey wire setup! I have tried to connect the black with black and red with red however the siren continously sounds. Is there a way around this problem?
  • 43 Answers
If you're connecting at the alarm module - you want the red wire from the siren to go to the brown wire on the alarm(the one that's in a plug with 12 or so other wires), not the red (red wire is the constant power input to the alarm).
Posted on Feb 24, 2008
How to disconnect the alarm
Depending if it is a aftermarket or a factory alarm, they should all have fuses that can be removed. By removing the fuse, you may lose your keyless entry option. Most aftermarket alarms have a siren that is usually mounted under the hood in the engine compartment area. I've seen where people have cut the wire going to the siren to disable it but keep the power going to the alarm system to keep the keyless entry still functional if it came with the alarm system.
Factory alarms usually use the existing horn for the alarm. If that is the case, you might need someone who is experienced to disable the circuit so that the horn will not sound if alarm goes off but the horn will still be functional when needed. Hope this helps.
Dec 20, 2014 | Cars & Trucks
How to install the alarm speaker for a viper
from the siren 2 cables come out, one black and the other red, the red one goes to the siren output (brown wire)
Apr 02, 2014 | Remote Start System
The siren has two wires: connect the red wire to a fused battery source. Connect the black wire to one side of a two wire toggle switch. Connect the other wire of the two wire toggle switch to a chassis ground. Now you can control the siren by applying the ground when toggling the switch.
May 24, 2013 | 850 Back Up Alarm - 107 Db Reverse Mount
I think my brain burned out. at first the alarm siren didn't beep or go off when i hit the car and lights didn't flash, the wire for the siren was cut and moved to a hidden location than wasnt wire when i...
disconnect the 5 pin harness, it has a red, brown, black, white, and red/white wire on it.
the brown wire in that specific harness, is actually the wire that runs to the sirens RED wire.
Feb 14, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
I have a Gemel Serpi Star alarm gr40 fitted to a 1991 bmw E36, I need to find a wiring diagram, can anyone help. Thank you
Im trying to fit an E90 siren to my E36. Were you every able to get the siren working? please email me at either way
Apr 21, 2010 | Anti-theft Alarm System 3 Series E90 E92...
Just installed smart siren kit, worked ok for 1
Harley alarms, while a decent alarm system, are notoriously hard to set up. On a new installation I have sometimes had to run the set-up routine 4-5 times. I hope you have an owner's manual and/or good instructions. Keep trying to set the alarm up from the beginning. If you miss a key or time limit it's not unusual to have the set-up fail and you have to start all over. Disconnecting the battery will screw things up, so be careful.
Oct 02, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
Newly installed car alarm, LED in solid light n horn/siren blares
if you follow instruction properly than the alarm should work properly, Go over your wiring again 2-3 times make sure it make sense to you with the instructions. If it make sense than take the unit back and get another, can be faulty alarm.
Aug 26, 2009 | 2003 Toyota Corolla
Ademco 4160-12 was installed in my house in 1987.While exterior painting, the external siren wire is cut. Please help me find new siren and procedure to alarm system. This has at present only local ( siren...
any 12 volt siren will work. you my have to replace the fuse. 12volt sirens are available at radioshack, frys electronics and all over the web,
Aug 06, 2009 | Ademco CIA Modem
1988 nissan maxima factory alarm faulty
try locking and unlocking the doors with the keys that is what i did and it solved my porblem
Jun 23, 2009 | 1988 Nissan Maxima
Try to panic the alarm if that does not work then your siren is probably bad also check the wiring leading to the siren to make sure it is connected......
Feb 15, 2009 | Viper Security and Remote Start System...
Car Audio & Video Logo
192 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
