Question about Maytag 24 in. MDBH970AWS Built-in Dishwasher
Door handle broke
My door handle popped into the door and now it is locked. How do you get it out so I can open it?
    President:
  • Maytag Master
  • 2,651 Answers
.with a little luck you can try jiggling it for a while youmight get it ot pop open, if not youll needs to remove it from under counter. its held under countertop by 2 phillips screws (dropping the adjustmendt legs under unit will give you additional clearance to acess the screw head. after sliding d/w foward only 3 or three inches you gain acesss to the strike plate thats locking your latch. youll need to replace door latch and/or handle.
Posted on Feb 24, 2008
Can't open 2002 VW Polo rear door from inside or outside. Lock button does not go up when car unlocked. Tried hooking mechanism through door handle but still no good.
Hi:
Most likely the power lock/unlock solenoid in the door has seized up or rusted, not allowing the door to open or unlock. If the inside door panel can be removed, with the door closed, you should be able to disconnect/ or replace the door lock solenoid and be back in business.
Nov 02, 2017 | Cars & Trucks
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
BMW523i front passenger door will not open either by remote action or by manual ? the actualknob does pop up and down when useing the fob but still the door will not open . PLEASE help
sounds like the handle clip inside door popped off or broke[there are rods for locks and rods for door handles ] if can open from inside remove door panel and check clip at door handle the clips usually pops or breaks during winter ,cold days most auto stores have these clips
Apr 09, 2013 | 1996 BMW 523i
Repair driver side door
tHE DOOR PAIEL IS SURRONDED WITH 6 TO 8 PLATIC RETAINERS THAT SNAP INTO THE DOOR FRME.WHEN YOU TRY TO POP THEM OUT FROM THE DOOR FRAME BE CAREFUL NOT TO SNAP OF THE RETAINERS. yOU CAN DO THIS WITH A SCREWDRIVER. " may be a screw in the door handle or the pull handle. Sorry about the caps lock was on. hope this helps.
Tommy
Jan 07, 2012 | 2000 Dodge Intrepid
Rear door of 1997 QX4 will not open. The handles move but will not operate the door latches
the door latch cable sounds broke or the the door lock spring has popped, try open the door from the inside by removing the panel and pulling the cable. hope this helps ( rate me thanks )
Aug 30, 2010 | 1997 Nissan Pathfinder
Door handle broke, can't open door from inside but still from outside
the inside door handle railings probably popped off, its a long bent to shape piece of metal running from the handle to the switch, you will need to take the inside door card off using a screw driver and popping the clips out, peel back the plastic cover enough for you to see, use a torch to see where it has popped off and clip it back in, if you try using the handle and you can hear the metal rod moving around it mights still be attached but the retainer clip has jumped off clip it back in. should solve your problem, if its all still in tact check to see if the child lock feature is working properly and isnt stuck to the lock mode. cheers hope it helps :)
Jun 22, 2010 | 1995 Buick Century
2007 chevy tahoe driver side door handle will not open door
the linkage behind the handle either the retaining clip broke or popped off need to remove the door panel to check and fix
Mar 13, 2010 | Chevrolet Tahoe Cars & Trucks
In my 1996 toyota 4 runner my driver side door opens only from the inside. The locks still work and it still opens but not from the outside. How can I fix it?
you have to remove the inside door pannel first remove the arm rest two screws then remove the door latch assembly then remove the crank handle by removing c clip around the wndow knob unless electric, next pop the lower and side screws out of the corners then pop the snaps up from the door remove the lock tab at top pull pannel next gently remove the plastic that covers the door and straighten the rod out on the inside that goes to the outter door handle, if it's not hooked up then you will have to buy a plastic clip from toyota to replace it with.
Aug 14, 2009 | 1996 Toyota 4Runner
How to change it myself
get a manual from the library or parts store; usually a couple of nuts on the inside of the handle. Doable but frustrating.
May 30, 2009 | 1994 Toyota Corolla
1998 Pontiac Firebird Door Schematics
If you have shaved door handles, usually there is a manual opener somewhere close. Some people install them under the car so it can be popped with your foot or sometimes they're located in the wheel well.
Jun 23, 2008 | 1998 Pontiac Firebird
Maytag 24 in. MDBH970AWS Built-in Dishwasher Logo
181 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
