Question about Radio Shack Pro-97 Handheld Scanner
Radio shack pro97
I just bought one on ebay and i cant even get the squelch to make any noise .it might be a older one but i'm not sure it looks brannew and just like all the pictures on radio shack website is there a certain way you have to program them?
  • 8 more comments
  • stleach1215 Feb 24, 2008
    just printed out page 13 to 25 of the easy understand manual
    this scanner puts out no sound at all other than the beeps when you push a key . i can't even get sound with squelch turned all the way either direction. any idea whats wrong?
    thanks steve
  • stleach1215 Mar 02, 2008
    you have the same problem i think the finals are burnt out but thats a uneducated guess
  • hoakmobil69 Jul 10, 2008
    I HAVE A RADIO SHACK PRO 97 SCANNER WAS WORKING JUST FINE THEN SUDDENLY THERE WAS NO SQUELCH OR VOLUME. THE KEYS MAKE NOISE WHEN PUSHED, BUT THERE IS NO SOUND FOR THE SQUELCH OR VOLUME. THE SCANNER SCANS FREQUENCYS. HELP
  • ama_ename Aug 12, 2008
    I went to radio shack and had them program my pro-97 scanner. It was working fine until I got home. No squelch, and never picks any thing up except weather stations! Help!!!
  • shara_315 Aug 29, 2008
    i just got this scanner off ebay i need a manual
  • lemkorusyn Oct 29, 2008
    Same problem here. Had the PRO-95 for years, then one day it would scan all day and not find anything. Bought a PRO-97 to replace it. It's been a great scanner for about 2 years now. All of a sudden, same thing. It'll scan, beep when I press the keys, I can program it, basically everything "looks" normal, but it doesn't "hear" anymore and I can open the squelch up entirely and it still won't find any activity or even allow me to hear the squelch. Reset it over and over, didn't help.
    I will say that right before both units died, I was using the power supply instead of running off battery power. I'm not sure if there's an issue with surging or what. Two Radio Shack scanners died on me now. Not sure I'll get another one. Very frustrating.
  • jsnidly Nov 25, 2008
    Ditto here. Scanner worked fine, moved to Pahrump,Nv reprogrammed the channels. Nothing, no SQ sound, no weather stations. I can see it scanning but can't get any sound I know the speaker is working. What is my next move?? Throw it out??? Try to fix it??? HELP !!!!
  • kweed555 Dec 27, 2008
    just got a brand new pro97 and no sound or squelch,no weather just scans and scans
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Do you have the manual?
Had this same problem with my old PRO-95. Bought a PRO-97 to replace it. Same things after about 2 years. Good scanners while they lasted. But they both died with identical symptoms. Working fine for about 2 years, then all of a sudden they would scan but not find anything. I can no longer hear the squelch even if I open it all the way up.
BEWARE: Both the PRO-95 and PRO-97 died while using the power supply as opposed to running off the battery. I think Radio Shack's power supplies must have a regulation issue or something.
Posted on Oct 29, 2008
I have the same problem too...Doesn't pick up ANYTHING! All of a sudden, nothing. Spent years programming it, and every frequency I found. Then one day......................................searching, searching.............
SO! Then I took the case off one day and held the battery to the terminals with my fingers and turned it on. It caught a frequency...the weather station! Then a short 3 seconds later the screen flashed, "low battery" and the backlight flickered rapidly on and off about 5 times and it turned off. Replaced batteries, turns on...........searching.........searching.......nothing. And it ALWAYS got the weather stations before. Waste of $225. Damn RadioShack!
Posted on Oct 04, 2008
I have the same problem anyone have any solutions????
Posted on Jun 30, 2008
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Posted on Feb 28, 2008
Radio shack noaa desk scanners squelch sound unit wont scan
If the squelch is on, there can't be a loud noise. Either the sqelch is completely off or you are not tuned to a station. NOAA broadcasts are continuous, not intermittent
Oct 01, 2012 | Radio Shack Radio Communications
Does not receive
It is posible that you may get some very close signals to show up but even that is not 100%
Make sure you also have any noise blankers etc turned off as these will further reduce the signal.
Check out some of the radio ham and scanner sites like Strong Signals you should find cheap ways of making a home brew ant. for it.
Sep 09, 2009 | Radio Shack Pro-2018 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Cant change the greeting on a pro97
The greeting can be changed using the USB programming cable and a software package such as Win97 from StarrSoft. (www.starrsoft.com) This is not freeware, but they do allow a 30 day fully functional trial. The greeting cannot be changed from the keyboard.
Jan 16, 2009 | Radio Shack Pro-97 Handheld Scanner
I have a new pr097 scanner and programed it fine but i get nothing recieved not even weather channel thay scan all fine but it dont stop on anything i cant figure it out also on my old scanner when you...
im just going to radio shack and return it for the only other one they have in stock which only goes to 512mhz whics stinks but at least i will recieve something wwhich is better than nothing
Dec 27, 2008 | Radio Shack Pro-97 Handheld Scanner
NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio shack hand held scanner Cat. no. 20-315
L live in Haywood county NC and I am running the following Radioshack scanners: Pro82, Pro95 and a Pro97. When will the rebanding take these scanners down. Also will the Pro97 beable to be rebanded as it really is a good scanner.
Nov 10, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
364 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
