Question about Compaq Presario S6000NX (DQ178A#ABA) PC Desktop
No singal to monitor and a long beep sound..
No signal to montior and a long beep
Smash both pc and monitor
Hori
Posted on Feb 24, 2008
Monitor works perfectly, but after a recent crash of my comp. Ive lost all sound ..The comp doesnt seem to recognize the build in speakers..
The computer does not have to recognize the powered speakers that are built-in the monitor, the computer feeds the analog audio signal the powered speakers inside the montior, there is no driver needed either, but you do need the PC sound card driver for you to get sound through any powered speakers (either the desk top powered speakers or the one inside the montior).
Since your computer had crashed, the driver for the sound card may be have to be reloaded.
You can verify if the monitor speakers are working or not by feeding it with an MP3 player or sound output from CD player.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 14, 2011 | BenQ FP72E 17" LCD Monitor
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
I have a Viewsonic VG2021m.. I think the speaker (s) is not working. There is no sound coming from my monitor.
your monitor have 4 buttons in the right down. the first is for turn on or off the speakers ;)
Apr 28, 2010 | ViewSonic VG2021m LCD Monitor
Vx2035wm
It sounds like your monitor is looking for an analog signal from the D-SUB connector while you are using the DVI connector. Go into the monitor's main menu and choose Input Select. Change the setting to Digital. You should now see yourr desktop.
Feb 22, 2009 | ViewSonic VX2035WM LCD Monitor
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
Video monitor
This means the monitor is not receiving a video signal
check your monitor connection or monitor cable for bent pins
thanks for rating
Jan 10, 2008 | Computers & Internet
I have the SAMTRON 56 V 14" COLOUR MONITOR .
change the eprom (A41dDC) after connect pc then switch on monitor
sushil91077rajbanshi@rediffmail.com
Sep 04, 2007 | SAMTRON 78DF 17" CRT Monitor
Computer does not start
Before we begin we?ll need some more historical information: -Was this a functional computer that just stopped working or is this something you?re building? -If this was a working computer were any new programs, hardware, drivers or updates anything that changed recently? -Have there been any recent error messages?
Mar 22, 2007 | Intel D101GGC Motherboard
Compaq Presario S6000NX (DQ178A#ABA) PC Desktop Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
