Question about Mitsubishi VS-50605 50" Rear Projection Television
TV problem I've got 6.3vdc across D953. Where do we go from here? REDCAT55
  • REDCAT55 Feb 26, 2008
    I am still in the process of locating the part I need [IC951]. So i'm not sure if problem is cured yet. REDCAT55
  • Mitsubishi Master
  • 8,617 Answers
1) Unplug the AC cord.
2) Connect a 100 Ohm resistor (R) between
pins 4 and 5 of the IC951. This discharges C960
that may still be charged if the Over Voltage
Protect circuit was activated.
3) Remove the 100 Ohm resistor and apply
power to the set.
If the problem still exists, the IC is probably defective.
Posted on Feb 24, 2008
No vertical everything else is ok
Check and replace all the electrolytic capacitors {5 or 6 of it} at its vertical scan output section circuit. Replace all at one time. be sure about the polarity of these capacitors when replace it. As you know, all electrolytic capacitors have both +Ve and - Ve terminals, must coincide with to that the marking at the PCB. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts.
Dec 29, 2013 | RCA F32649 32" TV
Why does my dvd player have two pictures with PSCAN displayed across the screen?
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Jul 16, 2010 | Memorex MVD2022 DVD Player
TV problem
you have to lift one leg out of circuit and touch the leads to each end of the diode then reverse them and take the second reading,
Mar 08, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
Use the analog meter reverse your probes you should get no reading one way and get a reading when the probes are reversed. You will need a diode vhecker to test for a leaky diode as often times a diode will fail under load. Its best to replace a questionable diode if you dont have an actual diode checker meter.
TV problem
Check the diodes and regulators out of circuit that feed the IC especially pin 1 and pin 4
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
Let me go over the schematics and I will post what i can find that maypossibly keep taking out the IC
Tv problem
Check the connections on your front control panel PCB to see if they are all secure then trace them back to where the plug into the chassis and check the connection there as well
Mar 01, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
Over Current Protection
Pin 1 of IC951 is also the Over Current Protect input.
The internal FET.s ground return is at pin 2 of
the IC. The voltage drop across R955 and R956
indicates the FET.s current, and is coupled through
R953 to pin 1 of the IC. The Over Current Protect
circuit is activated if the voltage at pin 1 of the IC
exceeds 1.35 volts.
Stabilization and rough regulation are provided by
feedback from pin 3 of T951 to pin 1 of the IC. Fine
regulation feedback is from a secondary supply,
through the Photo Coupler, PC951, to pin 1 of IC951.
Its possible that Diode D953 is leaky allowing the voltage to rise on pin 1 of the IC
Feb 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
DEAD TV
Look for 2 resistors off of pin 2 of IC951 R955 & 956 they are hooked in parralell and the tail end of those resistors are grounded.
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
