Question about Sony KP-57WS500 57" Rear Projection Television
NO PICTURE, ONLY AUDIO.
5 INTER-MITTEN FLASHING LIGHT ON CONTROL PANEL.
PICTURE TURNS OFF FOR A SECOND AT IRREGULAR INTERVAL.
FINALLY PICTURE TURNS OF PERMANENTLY. AUDIO IS STILL ON.
    Scholar:
  • 51 Answers
Hi
Your TV is trying to tell you what is wrong with the red flashing.
Five flashes means that you have a white balance problem or the x-ray protection is enabled.
Although I could tell you how to solve the problem, this is not really something you should try and do by yourself.
If your set has Tele-Text that is most likely where your fault comes from. This is however something a Sony techinician should fix.
Sorry about the bad news.
Good luck.
Posted on Mar 08, 2008
Keeps cutting out icluding the electrics
Check clean and tighten battery terminals . I once found a battery had been replaced over a wiring loom and the sharp side of the battery box had cut into it causing a inter mitten short.
Aug 11, 2014 | Peugeot 206 Cars & Trucks
Is there an inter-mitten relayswitch for delay wipers
No, but if you're having a problem with erratic wiper operation, check the contacts in the control board that bolts onto the wiper motor.The contacts become worn and create wiper motor problems. The circuit board can be purchased separately at most parts stores and is easy to install.
Jul 06, 2014 | 2004 GMC Sonoma
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
TX-47F430S seems to be the common problem of going back into standby. Powers up shows the logs and then goes back to low power. The light never goes blue. The fiber optical laser turns on and stays on but...
This is known as SLEEP MODE / STANDY MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control2_bing.gif. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These steps are done to over-ride the sleep mode.
Roan
Jan 29, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Turns on then off
Have you replaced the lamp before? If not i recommend you do it, but if you already have and it's acting this way there's a chance that your ballast has irregular voltage that's why it's not working the way it should
Jul 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture, audio flickers on and off
THIS IS USUALLY THE MAIN TOTAL ASSY OR THE PANEL IS BAD.
Jan 30, 2009 | Televison & Video
Sony KP-57WS500 57" Rear Projection Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
