Washing machine water coming out on the left side from the bottom
  • 96 Answers
Most probable cause is leaking pump or pump hose connection.
Posted on Feb 24, 2008
WHY IS WATER IS LEAKING FROM WASHER?
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
Jul 30, 2014 | LG WM2016CW Front Load Washer
While using washing machine water leaks out
sounds like the lower pipe or pump pipe is leaking or come away. you need to pull the washer out and place it on its side (left as you look at front) and check the pipes on the bottom, they have pincer clamps on the pipes, if the pipes are cracked or damaged replace them but usually its just they have come loose from drum movement. and just need fitting back on. also the drain pipe needs to be at least 3 inches from the top level with the water in pipes height of the washer so the water does not just come out.
Jan 13, 2018 | Washing Machines
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Water leaking onto the floor
hat leak may not be in the machine. It may be one of the hoses going into it. Look to find out where the water is actually coming from. If it is a hose from the faucet behind the machine, the hose can easily be replaced at a low cost. If it is only leaking with hot water, check the water inlet valve at the rear of machine where the hoses connect, top left rear facing it. If it is leaking and running down the left side, it is the wrong side for the pump unless it running across the floor and out the left side. If it were the hose, it would leak all the time. It sounds like the hot side has gone bad on the inlet valve. You can save several dollars by fixing this yourself.
Tilt it back and look for two screws, near each corner on the bottom front. Remove these screws and pull the bottom toward you. It should lift off the clips on top. Run the machine carefully, moving parts and see if the leak is actually coming from the left rear and from somewhere up high. First try cold water, then hot. If it leaks on one and not the other, then it is the valve. Be sure to unplug the machine if you decide to change this part. Also you might want to mark where the wires go back to be sure you do not reverse the hot and cold water, as well as fittings and connections. The water leakage evidence should be visible. If not, wash a load and watch for where water leakage occurs. Just look. Do not touch since there will be electrical current supplied.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
WASHING MACHINE LEAKING FROM BOTTOM
Check the two lengths of 1/4" plastic tubing, the long one that runs from the filler at the botton left side of the tub, and the short one that runs from the load switch (water level switch) to the shield assembly (formed plastic cover for the controls). When under pressure, the tubing can come loose from the plastic nipple on either side of the shield, leaking water while the tub is filling. If either length of tubing is detached from the nipple, reattach the tubing and use a 1/4" hose clamp to prevent it from detaching again.
Mar 14, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
The water pours out of the bottom of the washing machine
I think that you have a bad water jet. They are located inside the cabinet at the bottom of the washing machine. Mine was on the left rear corner, inside the cabinet to the side of the tub. Follow where the water hose goes into the washer. You will be able to fix it yourself. I didn't lay the washer down, the cabinet panels come off. Good luck. I have faith that this will be a breeze for you.
Jan 16, 2009 | Hotpoint Washing Machines
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
