Question about Sony STR-DE545 Receiver
Center speaker The center speaker plays for awhile and then it goes out. All the other speakers work so I have to switch to AFD mode or 2 channel mode. I have checked the connections in the back and everything is in tack. When I turn it on again in V multi semi or surround sound, the center speakers works again but for a while. What is wrong? I can hear it go out similar to the sound when I turn the receiver on or off. Thanks in advance for your help. Corey
  • koorie Feb 24, 2008
    Your comment was very helpful. It is such a shame that this receiver has this problem because it played so well. It'll probably cost between $200 & $300 to fix it. I've checked one repair place and it will cost $85 dollars just for them to diagnose the problem. I think that Sony should have a recall for this receiver or have their customers send it out to be fixed for free. I'll send them an e-mail to let them know of this flawed product.
  • Suswoman Feb 24, 2008
    I'm having the exact same problem with my Sony receiver model STR-SE501. I bought it a few years ago and it's worked fine up until a couple weeks ago. Now it's VERY annoying and the center speaker goes in and out at will. I took the cover off to see if I noticed any obvious loose connections, but couldn't tell. I also tried reconnecting all of the speaker wires and replacing the speaker wire to the center speaker, to no avail. Any assistance anyone has would be greatly appreciated before I spend money on other receiver. Thanks!
  • 4 Answers
Yes, this is a symptom of bad solder, especially the Blue Relay contacts. Re-soldering will fix it, I did it for mine.
Posted on Dec 07, 2008
  • 593 Answers
Mine is doing the same thing, you can hear a click sound and the channel will die. I think it is a relay or a shunt that trips when something goes wrong with that amp. I dont think it is worth repairing as there are some nice receivers out there for cheap. Maybe just a cold solder joint somewhere? Anyone know where and Ill dive in and resolder and post the results.
Posted on Feb 24, 2008
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Dav dz750k
Check your center channel. Most dialogue is routed to the center channel in surround.
Jul 24, 2013 | Audio Players & Recorders
I am not able to hear the dialog while playing DVDs. The background is great and comes through all 5 speakers, however, to be able to listen to the dialog, I have to switch over to 2-channel or Stereo. ...
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Sep 17, 2010 | Coby DVD765 Theater System
Connectivity
you have to make sure you are on the theater mode on your amp. that's the only time that the center speaker works
Jun 10, 2010 | Pioneer VSX-818V-K Receiver
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
if its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Jun 05, 2010 | JVC RX-888V Receiver
Center speaker
When you turn on zone 2 you are in stereo mode. The center speaker and the rear speakers will not function in stereo mode.
Try turning on zone 2 and then switch the surround mode after that and see if it helps. If it turns the zone 2 speakers off when you do that, then your unit does not support what you want it to do. Center speakers only work in listening modes other than stereo.
Most A/V receivers are designed for watching movies and they did not take this use into consideration because zone 2 would normally be in another room such as the way you have yours set up. If somebody is watching a movie in one room they would not need to hear it in another room. You would think that the designers, who are very talented to be able to come up with these type of units, would have just a little more imagination on how people would be using the equipment. Go figure!
If your receiver has a 5 or 7 channel stereo mode, it may work then. You can try, but I don't think it will help.
I have even seen some receivers that have the center channel amp being used for the zone 2 output as well. It just switches what speaker output jacks it goes to with a couple of relays which makes it impossible to use the center and zone 2 at the same time.
I guess they are just being cheap by not putting another output channel in the unit and sharing the one they have.
Why would anybody want to use the center and the zone 2 at the same time???? Sad, isn't it.
Hard to believe that such a nice receiver would have such a rediculous limit designed right into it. But they really do design them like that.
Let me know if you need more help.
Dave
Aug 08, 2008 | Yamaha RX-V2300 Receiver
Center speaker not working
Yes Mark, You have a problem with a componet with that center channel. If your not a tech, dont have a schematic, or dont have any training in troubleshooting solid state electronics, unhook everythuing and take it into a repair senter for an estimate, as unless you know how to chech the parts you can cause more damage to the unit as it takes one slip and boom, all gone. Good Luck
Jul 28, 2006 | Sony STR-DE575 Receiver
Sony STR-DE545 Receiver Logo
212 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
