Question about Dishwashers
Dc28 - Washing problems
Why does my tablet drop out half way through the wash. Even if I open the door and put it straight back ensuring that the compartment is closed it pops straight back out again!!!
Can you help
  • sarahhowe Feb 24, 2008
    In response to my question why does my tablet fall out mid wash. I should have added that:-
    The tablet is dropping out and when the cycle is finished it is still a whole tablet at the bottom of the dishwasher, and the plates are not clean.
  • Ron Coons
    Ron Coons May 11, 2010
    machine is opening detergent dispensor halfway through wash and your replacing tab why???? it meant to open
  • 105 Answers
This is normal how else is the dtergent going to be applied to wash
when the machine starts the fist cycle is generally a rinse cycle then next cycle is wash and this is when the dispenser opens and stays open for rest of cycle
Posted on Feb 24, 2008
What can I do to make it work?
I would have advised you before placing the tablet dry compartment with a dry cloths otherwise tablet would be stuck together. If does't help then put the tablet directly into the sink and never choose a quick program if you do not have functions (like 3 in 1, multi tab and so on....) that extend the time of duration of washing phase and give enough time for dissolve tab. Sometimes people on the upper basket hang up various odors or put dishes that may prevent to open small door to the end and dropping tablet.
The tablet most likely will drop during the washing cycle but the remaining time is not enough to dissolve the tablet and wash result will be bad.
Dado
Aug 16, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
Hotpoint DC28 not washing
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Jan 12, 2014 | Hotpoint 18 in. DC28 Slim-Line Built-in...
I have a foul smell coming from my washer everytime I use it...It almost smells like sewer gas...HELP!!!
you probably just need to clean the bellow. Thats the rubber that goes around the tub and door. f not cleaned, it will get moldy and smelly. Theres a tablet that you can buy called affresh. just put the machine on a regular cycle if it doesn't have a clean or sanitize cycle, and put the tablet in. Let the machine complete the cycle. (without clothes). You can even try wiping the bellow out with vinegar. after each wash i suggest you wipe the machine out, drying the bellow and glass. Leave it open for about half an hour, to let it air out.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
Smelly washer!!!!!!
Check the drain hose for gunk then:
Fill up the tub half way with water (small load) put a cup of vinegar a 1/4 cup of baking soda let it foam up then run the washer through a regular cycle empty. If this does not work: you will need to use a commercial mold removing product.
Mar 17, 2010 | Washing Machines
My hotpoint washing machine wmf540 keeps flashing 'door' when I try to put it on a cyle - but the door is shut!!! Any advice??
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency.
Jan 10, 2010 | Hotpoint Washing Machines
Musty/Mildew smelling clothes...
lg has a known problem with smelly mildew cloths. If you call LG they will tell you its not there problem. Cheapest solution is to wash door gasket with some clorox and then betwen washes leave door open. On the washing supply shelves there is a product you put in the washing machine run a wash without cloths and it does the same thing except it costs $7.If you bought it a t Lowes go back and ***** to store manager my friend did exactly that and got the machinje replaced
Sep 30, 2009 | LG WM2688HWM TROMM SteamWasher
Hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
The detergent dispenser sliding door will not stay closed
it is a very tiny plastic "tooth" that let open automatically the door when the washing program selected reach the opening point, the only good solution I suggest is to add the detergent after the first hot wash (just open the main door and drop it in!)...of course the best is to change this door locker with a new one...good luck!
Nov 17, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Dishwashers Logo
159 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
