Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Convergence have a Samsung HCP4752W Rear Projection would like to know all possible part to replace 3.9 ohm resistors how many? the 2 ic's and are they the same number believe to be STK392-010 and is an upgrade available? to get longer life? any fuses, or caps that should just be replaced because it is a good idea while I have the board out does not look like fun to do so only want to do it once. Thanks for your help
    President:
  • 4,402 Answers
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
STK392-010 replace with STK392-040
good luck
please mark the post with a fixya
Posted on Mar 14, 2008
Convergence failure Samsung rear projection television
usually on your model it might be best to replace the entire deflection board as your model has two STK394-250 ICs and then 12 3.9 ohm fusible resistors that will need to be checked and possibly replaced. If you need further assistance let me know I can assist with getting quality parts and circuit boards.
Oct 17, 2011 | Samsung HC-P4241W 42" Rear Projection...
I have a Panasonic Projection Monitor PT-47WX52C.When I turn on power it blinks 3 times .What do I have to do to repair it? Thanks Kathy
You will need to replace both convergence ICs and also possibly the associated low ohm resistors, since the 3 blinks is indicating that the convergence has failed. The PT47WX52 convergence repair kit is available from www.tvrepairworld.com which has the two ICs , heat sink paste, low ohm resistors and the CD with repair instructions.
Aug 22, 2011 | Panasonic PT-47WX53 47" Rear Projection...
2 resistors are burnt rz126 and rz125 but i dont know the value of these resistors samsung SPA43W6HPX
Both of those resistors are 3.9 ohm 2watt metal film resistors for the convergence ICs. The ICs will most likely need replacement as well.
Mar 03, 2011 | Samsung HCL4715W 47" Rear Projection...
I have a samsung hcp4752w and replaced the sub board, worked fine just need alighned in lower right corner, will not enter mute 183 power to adj convergence, will enter 182 fine. I checked all setting and...
Have You Replaced Convergence ICs,If not replace Both of them and 2 resistors 2.7ohms 1watt ICs are STK ICs big Black IC will have part number on them STK392-020. Mats Electronics has them in stock
1-800-628-1118
Feb 20, 2010 | Samsung HCP4252W 42" Rear Projection...
Hour glass bowing on the top and bottom of my HCP4752W Samsung
Check the resistors near the ic, and the fuses to the ic's, i bet you will find an open fuse. the fuse will look similar to a resistor without color bands. use a dvm and set it on ohms, with the tv turned off.
Sep 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
Replaced convergence board but still out of convergence. what's next?
1- Did you try converging it by way of your menu?
2- Sometimes they have fuse-able resistors on the deflection board that go open when the IC's take a dive.
3- If this doesn't help then I will need your model number and make and you will need to get your DVM ready for trouble shooting.
4- I haven't had to replace a convergence board complete in 20 years, I don't know why your wanted to do that. Replace the IC's and possible resistors and your back in business.
5- Let me know!
Jul 11, 2009 | Samsung HCM5525W 55" Rear Projection...
Do you have to buy a new convergence board to fix the blue and red convergence for a samsung tv
mo you can replace the two Convergence ICs and check the 3.9 ohm feed resistors. You can get new replacement ICs and resistors at the following link.
http://servicemanuals.vstore.ca/
Apr 20, 2009 | Samsung HCM5525W 55" Rear Projection...
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Samsung HCP4752W Convergence Problem
Each convergence IC has a fusible link going to the IC. On the foil side of the board you will see the fuse size, usually 3.15a. Check both with an ohmmeter, like you would check a normal fuse. Replace the one that is open and that should take care of your problem. Good Luck.
Apr 28, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Jerry Greenberg
Jerry Greenberg
